EDIT: Already logged as an issue. Workaround is to add color_palette: 8BIT to the device.. Workaround is to add psram: to the yaml config. The ILI9xxx used to enable PSRAM by default, after this update it no longer does. The 8BIT workaround seems to work for smaller displays but not for 320x240 ILI9488 3.2 inch.
Looks like 16BIT is the default but there was some undocumented detection of PSRAM that switched on 8BIT mode even if you left the default on. At least I think that’s what the breaking change fixed.
After update to 2025.2 the screen does not display any objects, simply a white background (all pixels on). Reverting to an older ESPHome build fixes the issue so not a hardware problem.
Going to recompile under 2025.2, just putting this out there for any “me too’s” before I do some more testing and log issue on Github.
Which reminds me - better check if one already open.
Yes, the ili9xxx component used to auto load psram which isn’t a Good Idea since it’s not an absolute requirement. The logs (serial) would have more info on what failed.
This “change” cost me literally an entire day lost to tearing apart my prototype, tracing circuit board traces, swapping ESPs, etc. trying to debug what had happened. Serial logs were of NO help.
Then figuring out how to roll back to 2024-12-4, another giant PITA since I don’t backup add-ons.
Stupid me had Auto Update turned on as my default in ESPHome. Lesson learned. The hard way.
So is there a “fix” for this or are we stuck on 2024-12-4 for now?
I tried the 8 bit part and that did not work. I can try the PSRAM: bit and see if that solves it. It would have helped if this was documented clearly. It wasn’t - I also scoured the docs looking for a solution,
I see the new notes. But doesn’t the psram section only apply to ESP32 boards that have psram like the S2/S3 boards? I am using an ESP32 WROOM (esp32D1Mini) with no psram…
My ili9341 works great on 2024-12-4. So I’m still questioning if it will work on the new release without psram.
If it works now without PSRAM it will continue to do so. You may need to specifically request 8 bit mode since that was previously being silently enabled if there was insufficient memory. But nothing changed that can’t be set with some config options.
For anyone else running into this with PSRAM: Just adding the above line worked for me to get the display with ESP32 s3 zero back to work.
Thx for sharing.
