Hello all,
since 2025.11 I have problems with my display. It is only Black, nothing is visible. With the latest 2025.10.5 all fine.
LOG:
[17:06:11.216][C][ili9xxx:089]: ili9xxx
[17:06:11.216][C][ili9xxx:089]: Rotations: 270 °
[17:06:11.216][C][ili9xxx:089]: Dimensions: 320px x 480px
[17:06:11.221][C][ili9xxx:090]: Width Offset: 0
[17:06:11.221][C][ili9xxx:090]: Height Offset: 0
[17:06:11.222][C][ili9xxx:102]: Color mode: 8bit 332 mode
[17:06:11.224][C][ili9xxx:106]: 18-Bit Mode: YES
[17:06:11.228][C][ili9xxx:108]: Data rate: 40MHz
[17:06:11.231][C][ili9xxx:110]: Reset Pin: GPIO38
[17:06:11.232][C][ili9xxx:111]: CS Pin: GPIO14
[17:06:11.235][C][ili9xxx:112]: DC Pin: GPIO42
[17:06:11.238][C][ili9xxx:114]: Color order: BGR
[17:06:11.238][C][ili9xxx:114]: Swap_xy: YES
[17:06:11.238][C][ili9xxx:114]: Mirror_x: NO
[17:06:11.238][C][ili9xxx:114]: Mirror_y: NO
[17:06:11.238][C][ili9xxx:114]: Invert colors: NO
[17:06:11.241][C][ili9xxx:124]: => Failed to init Memory: YES!
[17:06:11.244][C][ili9xxx:363]: Update Interval: 1.0s
[17:06:11.247][E][component:154]: display is marked FAILED: unspecified
Configuration:
display:
- platform: ili9xxx
model: ILI9488_A
# model: ILI9486
dc_pin: GPIO42
cs_pin: GPIO14
reset_pin: GPIO38
dimensions:
height: 320
width: 480
auto_clear_enabled: True
invert_colors: false
rotation: 270
# show_test_card: true
color_palette: 8bit
pages:
- id: page1
lambda: |- ...
What can I do for enabling the display again.
Kind regards
pepe59
(Pepe59)
November 26, 2025, 5:18pm
2
You can try this
display:
- platform: ili9xxx
model: ILI9488_A
dc_pin: GPIO42
cs_pin: GPIO14
reset_pin: GPIO38
dimensions:
width: 480
height: 320
rotation: 270
pixel_mode: 18bit
color_order: rgb
auto_clear_enabled: true
color_palette: 8BIT
Hello Pepe59,
thank you for your idea, but it did not work, same reaction like before. Black Screen.
You probably need to configure PSRAM. And/or switch to the newer mipi_spi display component.
alob85
(alob85)
January 22, 2026, 10:53pm
5
Hi there, thank you @clydebarrow for your hint! Worked for me for my Elecrow 2.8inch 240x320 display with ESP32-WROOM-32E / ESP32-D0WD-V3 chip with ILI9341V display driver (Elecrow DHO26028B), finally. This device has no PSRAM and that was the issue. However, display works now! Thanks!
esphome:
friendly_name: ESPHome Web 6a0048
min_version: 2025.11.0
name_add_mac_suffix: false
esp32:
variant: esp32
framework:
type: esp-idf
# Enable logging
logger:
wifi:
ssid: !secret wifi_ssid
captive_portal:
spi:
- id: lcd
clk_pin: GPIO14
mosi_pin: GPIO13
miso_pin: GPIO12
- id: touch
clk_pin: GPIO25
mosi_pin: GPIO32
miso_pin: GPIO39
i2c:
sda: GPIO27
scl: GPIO18
scan: true
font:
- file: "Helvetica.ttf"
display:
- platform: mipi_spi
model: ILI9341
spi_id: lcd
cs_pin: 15
dc_pin: 2
lambda: |-
it.line(0, 0, 50, 50);
it.print(0, 10, id(helvetica_12), "Hello World!");
output:
- platform: ledc
pin: GPIO21
# Define a monochromatic, dimmable light for the backlight
light:
- platform: monochromatic
output: former_led_pin
name: "Display Backlight"
restore_mode: ALWAYS_ON
Idea sponsored by GitHub - BOlaerts/ESP32-2432s028: Home Assistant integration using ESPHome on an esp32-2432s028 board, featuring I²C expansion and touchscreen functionalities
