Im New and need all the help i can get
I have google home a bunch of limitless lights in the home.
I have speakers all through the home
I have a pi ruinning kodi on my tv with lightberry.
I want to undertsand where to start and what i need.
I am good a following insturctions but am struggling to find an all in one place walkthrough.
In simple terms I want to be able to use google voice to turn on and off my lights in the first instance.
I have looked at home assistant and it seems to be the starting point but do I also need huge emulator even though the lights arent hue.
If anyone can point me in the right direction and tell me what i need. does it need to be pi3 or will pi2 be ok.
Sorry if the answer is here already but i cant seem to find it.
Thank you and go gentle im new :slight_smile:
Start with a RPI2 or 3 - doesnt matter
and this tutorial - with HASSbian you wont need to bother with the installation of pre-reqs, such as python and pip, its all done for you
https://home-assistant.io/docs/hassbian/installation/
Get familiar with the UI by playing about a bit… start to look at the configuration YAML files to get an idea of whats going on and how to change stuff in the front end
The next best place for learning how it all hangs together, is the cookbook where people have various examples of their system set up.
And finally, this community is great at helping out other people - so dont be afraid to ask any questions, big or small and even if you think its a stupid question. I guarantee you, someone will be on hand to assist!
Good luck and welcome :slight_smile:
Thank you so much.
I will start tonight I have a spare PI2.
Out of interest could it run n the same Pi I run for the Kodi box for the tv?
Last do I need hue emulator also to control limitless lights at all.
thanks again.
I wouldnt even try installing alongside Kodi.
What is the OS you run with Kodi on it?
If its something thats designed to run Kodi specifically, like LibreELEC or whatever, you’ll find its going to be difficult to set up Home Assistant - although it is entirely possible if you know what youre doing
The other problem you may run into, is performance. not sure if theres enough resource for both on a Pi2 ?
With regards to an emulated Hue, not sure. I run an actual Hugh Bridge and have never needed to.
Your aim is to control your lights with your voice via google home.
Are your lights these ones??
In the case of voice control, yes is the short answer - you will need to create a Hue bridge. The long answer is probably a bit advanced at the moment, but it is entirely possible for you to get to where you want to be - there are a lot of threads on here around google home, hue and controlling various things via the emulated bridge
Yes correct lights.
Would a hue brdge need another pi or can it be on same one. probably getting ahead of myself but I find when I throw myself in at the deep end i do better
and can an official hue bridge controll limitless as if so I will just buy one to make life easier…
I just dont want to buy hue bulbs as so expensive
Not sure on your emulated hue on the same host question as I dont run it. For simplicity, id just run it on the same installation and use the localhosts IP for it when needed.
There is a few light controllers that work with Hue, but generally no, out of the box, the official Hue bridge will only work with Philips Hue branded lights/lamps/LED strips
In the first instance, id get your HA set up on the Pi and add the Limitless LED config lines to your config as above link. See what functionality that gives you, then look into controlling it with your google home via the hue bridge
You have been super helpful thanks and we will see tonight how I get on
Standby for update :slight_smile:
Good luck buddy
And remember, dont do everything at once, add each config line one at a time
Otherwise, if you do something wrong, you wont know which of the components you added needs troubleshooting :slight_smile:
Will do and thanks for the entry into this mad world
quite looking forward to it
Emulated_hue just makes your home assistant react like a hue bridge so far as Google Home and Amazon Echo are concerned.
So if you had a genuine hue bridge and shouted “Hey Google, switch on the living room lights” the Hue bridge takes care of it.
If you use Emulated_hue, you shout the exact same command, Google Home thinks it’s talking to a Hue bridge but really it’s your home assistant, and home assistant takes care of it.
I have both a hue bridge and Emulated_hue here, and I only let my Amazon Echo see the emulated_hue on home assistant. If I command one of the Hue lights to do something, home assistant tells the Hue bridge to carry out the task.
Hope this helps.
It does but if I am correct I need both running on seperate pi2s
Been reading so much today.
Am I correct in reading I can use a NAS drive and install home assistant on it. (cant think that can be right but thought id ask)
I have a buffalo Nas drive. Just trying not to spend money i dont have to so I can waste it on bulbs sockets etc etc
You don’t install it on a separate pi, you just add the line emulated_hue: to your home assistant configuration with the appropriate configuration options and you’re done.
Im New remember but thank you very much is there a link to adding it ie one example and i should be good to go
So looking forward to getting my head into this tonight…
Guess the missus will get fed up with me but hey ho
Im guessing google home sees the hue emulator so I just add it… Maybe I am getting way ahead of myself.
There are a few more options you can try:
Hassio: https://home-assistant.io/hassio/
And, if you are running (the latest version of) LibreElec, it has support for Docker, so you could run the Home Assistant docker image if you wanted to.
Tbrasser are you saying I can run libreelec with home assistant on the same Pi
as such have it running kodi and home assistant
LibreElec 7.90.009 is what I am running.
Yeah, take a look at this tutorial:
But then instead of the docker-run command for ha-bridge, use this page:
Only at the end of the command instead of the standard image, you’ll need the specific raspberry pi image:
for rpi1:
homeassistant/raspberrypi-homeassistant
for rpi2:
homeassistant/raspberrypi2-homeassistant
for rpi3:
homeassistant/raspberrypi3-homeassistant
That looked all quite straight forward until the docker bit.
I would be using windows but got confused at the
When running Home Assistant in Docker on Windows, you may have some difficulty getting ports to map for routing (since the --net=host switch actually applies to the hypervisor’s network interface). To get around this, you will need to add port proxy ipv4 rules to your local Windows machine, like so (Replacing ‘192.168.1.10’ with whatever your Windows IP is, and ‘10.0.50.2’ with whatever your Docker container’s IP is):
Maybe im trying to run before I walk…
The 192.168 needs to be change to the IP of my PC and the 10.0.50.2 needs to change to the ip address of the PI
Correct
But once ive done that it gives me no code to send unless inm going mad
This is for docker on raspberry pi. So it has nothing to do with your windows pc.
Ah I see now what your problem is. Just use the linux docker install command, no need to read any further on that page.
Edit: So just follow the first tutorial but instead of running ha-bridge, you’re going to run home assistant.
This should be the correct docker-run command for that (on a single line):
docker run -d --name="homeassistant" -v /storage/docker/homeassistant:/config -v /etc/localtime:/etc/localtime:ro --net=host --restart=always homeassistant/raspberrypi3-homeassistant
I checked the tutorial and it wasn’t explicitly mentioning that you need to run that command from the raspberrypi’s/libreelec’s shell. You can connect to that via SSH on windows using Putty, or directly from the commandline on OSX and Linux. Default LibreElec ssh (when enabled from Kodi options) is: user:root password: libreelec
If it all works you should be able to reach home assistant via http://raspberrypiIP:8123/
Thanks.
Had a bit of a mare setting it up. My Pi" kept failing to install any setups so had to drop it for the night.
Im going to pick up a Pi3 this afternoon as it got me thinking if every the Pi2 needs updating I run ligtberry for tv ambient light. When i update im back to square one. with seperate device for ÂŁ30 seems safer.
