In my house I do have couple of analog gauges: measuring pressure in heating system, overall water pressure, and abit ancient gas heater which is not “smart”.
Quite often I’m not there, but supervision is required for the heating system.
It also had problem with heating system pressure, which if goes down may cause critical failure in heater and in pumps.
I did the monitoring manually, through IP camera, and then got an idea to automate analog gauges readings into the sensors of HA.
Hi @irusskih,
just want to thank you, I was searching for something exactly like your solution, since I need to investigate my changing heating system’s water pressure. it’s working perfect!
@s-bed I did it this way: Copied the image from camera preview in Browser, pasted it in IrfanView, selected the area of interest by mouse and read the coordinates and width/hight from title bar of window. Worked instantly.
