Imbrication of condition
hello,
is it possible to put 2 conditions, but 1 inverted with “not” in same “if”?
- if:
            condition:
               - switch.is_off : template_switch
               not:
                   - script.is_running: delayscript
            then:
              - light.turn_on: light_led
            else:
              - logger.log: "bouton pressé, mais sonnette desactiver pour deux heures"
thank you
Sébastien
Don’t post images of text.
But lambda condition is possible.
OK can you show me an exemple please ?
sorry for image, there is no balise menu in android app.
Something like this:
        - if:
            condition:
                lambda: |-
                        if(id(template_switch).state == true && id(delayscript).state == false){
                          return true;
                        }else{
                          return false;
            then:
            else:
thank you
assuming the id’s is correct. But I have no way of knowing if it is.
Thank you Hellis81 for your reply,
I have find the correct solution here:
   on_press:
      then:
      - if:
            condition:
                 lambda: |-
                  return !id(template_switch).state && !id(delayscript).is_running() ;
            then:
            else:
              - logger.log: "bouton pressé, mais sonnette désactivée pour deux heures"
