I have two CoCo (KlikaanKlikuit) dimmers ACM-100 built into the wall.
I have two CoCo rotating dimmer knob WRT-1000 (new product) attached to the wall. These 2 are binded together and that Works fine
Next, i have set the RFLINK in HA to auto add to learn the Signal from the dimmer knob in HA. This also Works fine, I can control the dimmer from HA (on/off and dimmer).
The two dimmer knobs are recognized as: (id’s are both anonemized)
newkaku_012345ab_c
newkaku_012345bb_c
If I turn the lights on by pressing the dimmer knob, an ON command is Send and this is also detected by HA and the status of the light Goes to on.
Same for turning the light off by pressing the dimmer knob twice. The OFF command is sent and received by the RFLINK and sent to HA. The status of the light in HA is set to OFF.
What doesn’t work is when I rotate the dimmer to change the intensity or when I turn on the light by just turning the dimmer knob. The light turns on, but the status in HA is not updated.
I started RFLINK debugging in HA and I see the set_level command coming in HA through RFLINK.
2021-02-12 10:36:38 DEBUG (MainThread) [rflink.protocol] received data: 20;03;NewKaku;
2021-02-12 10:36:38 DEBUG (MainThread) [rflink.protocol] received data: ID=012345ab;SWITCH=c;CMD
2021-02-12 10:36:38 DEBUG (MainThread) [rflink.protocol] received data: =SET_LEVEL=15;
2021-02-12 10:36:38 DEBUG (MainThread) [rflink.protocol] got packet: 20;03;NewKaku;ID=012345ab;SWITCH=c;CMD=SET_LEVEL=15;
2021-02-12 10:36:38 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'newkaku', 'id': '012345ab', 'switch': 'c', 'command': 'set_level=15'}
2021-02-12 10:36:38 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'newkaku_012345ab_c', 'command': 'set_level=15'}
2021-02-12 10:36:38 DEBUG (MainThread) [homeassistant.components.rflink] event of type command: {'id': 'newkaku_012345ab_c', 'command': 'set_level=15'}
2021-02-12 10:36:38 DEBUG (MainThread) [homeassistant.components.rflink] entity_ids: ['light.spots_boekenkast']
2021-02-12 10:36:38 DEBUG (MainThread) [homeassistant.components.rflink] passing event to light.spots_boekenkast
2021-02-12 10:36:42 DEBUG (MainThread) [rflink.protocol] received data: 20;04;NewKaku;ID
2021-02-12 10:36:42 DEBUG (MainThread) [rflink.protocol] received data: =012345ab;SWITCH=c;CMD=S
2021-02-12 10:36:42 DEBUG (MainThread) [rflink.protocol] received data: ET_LEVEL=14;
2021-02-12 10:36:42 DEBUG (MainThread) [rflink.protocol] got packet: 20;04;NewKaku;ID=012345ab;SWITCH=c;CMD=SET_LEVEL=14;
2021-02-12 10:36:42 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'newkaku', 'id': '012345ab', 'switch': 'c', 'command': 'set_level=14'}
2021-02-12 10:36:42 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'newkaku_012345ab_c', 'command': 'set_level=14'}
2021-02-12 10:36:42 DEBUG (MainThread) [homeassistant.components.rflink] event of type command: {'id': 'newkaku_012345ab_c', 'command': 'set_level=14'}
2021-02-12 10:36:42 DEBUG (MainThread) [homeassistant.components.rflink] entity_ids: ['light.spots_boekenkast']
2021-02-12 10:36:42 DEBUG (MainThread) [homeassistant.components.rflink] passing event to light.spots_boekenkast
2021-02-12 10:36:42 ERROR (MainThread) [homeassistant.components.wled] Error fetching wled data: Invalid response from API: Error occurred while communicating with WLED device at 192.168.1.174
2021-02-12 10:36:46 DEBUG (MainThread) [rflink.protocol] received data: 20;05;NewKaku;ID=0
2021-02-12 10:36:46 DEBUG (MainThread) [rflink.protocol] received data: 12345ab;SWITCH=c;CMD=S
2021-02-12 10:36:46 DEBUG (MainThread) [rflink.protocol] received data: ET_LEVEL=11;
2021-02-12 10:36:46 DEBUG (MainThread) [rflink.protocol] got packet: 20;05;NewKaku;ID=012345bb;SWITCH=c;CMD=SET_LEVEL=11;
2021-02-12 10:36:46 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'newkaku', 'id': '012345bb', 'switch': 'c', 'command': 'set_level=11'}
2021-02-12 10:36:46 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'newkaku_012345bb_c', 'command': 'set_level=11'}
2021-02-12 10:36:46 DEBUG (MainThread) [homeassistant.components.rflink] event of type command: {'id': 'newkaku_012345bb_c', 'command': 'set_level=11'}
2021-02-12 10:36:46 DEBUG (MainThread) [homeassistant.components.rflink] entity_ids: ['light.spots_uitbouw']
2021-02-12 10:36:46 DEBUG (MainThread) [homeassistant.components.rflink] passing event to light.spots_uitbouw
So the set_level command is picked up by HA through RFLINK, but the status of the light is not updated.
The light is configurated as following:
- platform: rflink
automatic_add: false
devices:
newkaku_012345bb_c:
type: dimmable
newkaku_012345ab_c:
name: Spots boekenkast
type: dimmable
Gr. Remco
