Hi there,
I have implemented the KNX integration under HA. Everything working fine but the dimming function under HA is not working, because there is no physical address suplied for that dimming actor funktion. Only the address for switching the actor on/off is given…
I do not use the yaml-Configuration. Only the Entity function under theHA KNX extension.
Thats weird, object 5 is a DPT5.001 % value and not a 4bit, it should say byte
That looks more like a relative dimming object that HA does not support. It only supports direct input of the % (DTP5.001)
Object 4 is the relative dimming, and looking at your group description that fits.
Can you screenshot the actor itself?
Edit: just saw you Screenshot So percentage value is not linked and thus you cannot add it to HA. You will need to make groups for value entry.
So you will need to add a middle group for Dimming Absolute and in that add the Group address for the light, best to keep the number the same as for the light in question.
For example:
Buro Licht links Switching is 1/1/0
So Buro Licht Links Dimming Absolute would be 1/6/0 (if middlegroup 6 is the free one) and then you drag the dimming object from the actor into that.
But just to be sure can you screenshot the whole “Beleuchtung” main group?
Like this:
Whats happens when u use the switch actions? on 1/1/0
Also you said you updated the programming in ETS, did you use the download on the actor in question? Cuz it seems the actor is not reacting to the command from diag and HA.
How are you communicating with the KNX bus? if its an IP interface/router did you update the filters? or tried disabling the filters on the IP interface?
Did you try to send on/off to 1/1/0 via ETS yet? And what reaction did that give?
This very much looks like the telegram is blocked and most of the time its the IP interface that hasnt had its filters updated.
I’m communicating via IP interface IP-Router (MDT SCN-IP100.03) in secure Mode.
On Each line, there is a Line Coupler (MDT SCN-LK001.03).
The media type on each line is “TP”
How can I update the filters?
The signal on/off to 1/1/0 via ETS is working fine!
So from the IP router are there any Line Couplers in between it and the actor?
Like i said this seems like a filtering problem thats either in one of the couplers or the router.
You can to test just forward telegrams in the router and couplers. Depending on how much traffic there is, its best to filter.
Routing: add a dummy device with the same address as used by HA (eg. 0.0.240), assign the new GA to this.
Tunnelling: add the GA to the tunnel endpoint (no dummy in this case) HA uses. And since you use MDT-device I’d recommend to disable Data Secure for those GAs to avoid a bug in their firmware.
Then update the line coupler and router (should be listed in the automatic folder in ETS).
