Import blueprints not working
Hi
for the last couple of days I cannot import blueprints, either from the blueprints page in HA or by clicking the ‘MY’ button on a blueprint page.
Both methods add the url to the dialogue but when I click preview it just spins for a while then comes up with a TIMEOUT error
This happens both from my nabu casa url or my ip address or homeassistant.local
any ideas?
Hello Dave Clarke,
First off, have you restarted Home Assistant?
Is there anything in the logs?
Moving this to installation category because it is a problem with youe installation somewhere.
Yes I’ve restarted Home Assistant, restarted the host (nuc) and my router.
I’ll check the logs
I have had the same problem for a few days now. I think an HA update broke it
I think it may have been a dodgy port on my router, swapped the cable to another port and it’s working now
not the ethernet port that caused, or fixed, your issue… you’d be having problems with all your network/internet use from that system, and it would be causing you to not even get to any pages. DLing a BP is 1000x easier for the system than loading a web page.
you may be right… not working again now.
Also other things are very slow.
Some things that are nothing to do with home assistant are very slow too
I’ve turned off IPv6 on my router to see if that makes a difference
Yup :grimacing: … for 2 days I had major issues
  1. try open an already-installed HACS add-on, it just hung.
  2. all notifications to mobile devices failed (Mobile Notifications fail, worked fine 2 days ago. Sometimes reboot fixes it for a few seconds · Issue #140636 · home-assistant/core · GitHub), when Persistent notifications always worked.
I rebooted multiple times yesterday while testing the notifications, pulling my hair out.
The last reboot ‘fixed’ everything. There is for-sure some bug in HA causing connection timeouts. Its 110% HA, as I UP/DL tons of stuff daily without any issues or slowdowns on my 300gbit connection.
yes my mobile notifications are not working either.
A reboot lets them work once and then nothing
had the same problem until I did like 5 reboots… All my Notifications Fail to send as of 2 days ago - works for a second after reboot - #4 by Didgeridrew
March updates hosed the network stability. I get tons of timeouts when trying to DL from HACS and BPs… it never works anymore. normal Integration DL/updates all work fine
