Hi, evcc is running as an addon directly in HA. I integrated a battery via modbus in evcc to steer the battery. However, I also would like to use the same data in HA to show e.g. the state of charge on my dashboard. If I‘m not wrong it is not possible to connect the battery twice, that means both via evcc and HA. Hence, I hope there is a way to use the data from evcc. Unfortunately, I don‘t know I can implement the idea. Therefore, it would be great if you can support. Thank you in advance.
