Hello everyone.
I’m trying to create an external component to communicate with an (Aurora) inverter. The idea is to use an existing library (which I’m using successfully with arduino ide - link to github) in the component.
Said library requires HardwareSerial to be initialized, like so:
HardwareSerial mySerial(2);
Aurora inverter = Aurora(2, &mySerial, 5);
But I could not get HardwareSerial to work. Here is what I get when using it:
src/esphome/components/empty_sensor/empty_sensor.cpp:13:1: error: 'HardwareSerial' does not name a type
13 | HardwareSerial mySerial = HardwareSerial(2);
Importing like the following doesn’t help as well:
#import "HardwareSerial.h"; //Same using <HardwareSerial.h>
I get:
src/esphome/components/empty_sensor/empty_sensor.cpp:7:10: fatal error: HardwareSerial.h: No such file or directory
In other topics it seems to work without even importing (like here), is maybe imported with a yaml directive?
Thanks in advance
P.s. I’m also open to other solutions to work with Aurora inverters. I found a repo on github (michelsciortino/esphome-aurora-inverter - apparently I cannot link it, as I’m a new user) but it uses a custom component, which is not supported anymore.
