Imposible to flash sonoff zigbee dongle plus same router
ZigStar TI CC2652P/P7 FW Flasher
s6-rc: info: service banner: starting
Add-on: ZigStar TI CC2652P/P7 FW Flasher
ZigStar TI CC2652P/P7 firmware flasher add-on
Add-on version: 0.4.1
You are running the latest version of this add-on.
System: Home Assistant OS 14.2 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2025.2.0
Home Assistant Supervisor: 2025.02.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service cc2652-flasher: starting
[18:51:33] INFO: Triggering Bootloader mode on /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_92c6841668afed1182f43b4e71c9e8b5-if00-
[18:51:36] INFO: cc2652-flasher-up script exited with code 6
s6-rc: warning: unable to start service cc2652-flasher: command exited 6
s6-rc: info: service banner: stopping
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service banner successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
[18:52:12] INFO: cc2652-flasher-up script exited with code 3
s6-rc: warning: unable to start service cc2652-flasher: command exited 3
[18:52:49] INFO: cc2652-flasher-up script exited with code 3
Continuing the discussion from Sonoffs Zigbee 3.0 USB Dongle Plus Firmware:
