This is my first post here.
I have an ubuntu config and i installed hass.io. Everything was fine (till now)…
But i have a little problem, impossible to access my HA in ssl.
I have a fix IP, so i don’t need duckdns or Letsencrypt. So i created my cert with openssl, i put the 2 files in folder.
i completed configuration.yaml like that:
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
I restarted HA and i have this error:
Invalid config for [http]: not a file for dictionary value @ data[‘http’][‘ssl_certificate’]. Got ‘/home/erick/certificats/certificate.pem’
not a file for dictionary value @ data[‘http’][‘ssl_key’]. Got ‘/home/erick/certificats/privkey.pem’. (See /config/configuration.yaml, line 26). Please check the docs at HTTP - Home Assistant
Well… First, i installed hassio in a raspberry. Then i bought an laptop on ubuntu, i tried to install home assistant but i couldn’t find “hass.io” menu (with configurator).
So i searched on google and found that tuto:
