Hi there, I’m migrating my HMA/Zigbee2MQTT configuration to a LXC container in proxmox.
I have migrated all files from the legacy setup onto my LXC container.
the /dev/ttyUSB0 exists. I have temporarily extended the rights to 777 to avoid access issue. The usb device is cc2652rb. I have configured the configuration.yaml this way:
version: 5
homeassistant:
enabled: false
frontend:
enabled: true
mqtt:
base_topic: zigbee2mqtt
server: ‘mqtt://mosquitto.familletaieb.fr:1883’
serial:
port: /dev/ttyUSB0
adapter: ember
advanced:
log_level: debug
network_key:
- 103
- 33
- 159
- 177
- 168
- 173
- 59
- 65
- 200
- 48
- 101
- 111
- 57
- 216
- 32
- 53
pan_id: 59915
ext_pan_id:
- 89
- 135
- 55
- 142
- 82
- 205
- 74
- 70
But zigbee2mqtt doesn’t start with the following error message.
Jun 12 19:05:21 zigbee2mqtt pnpm[425]: Starting Zigbee2MQTT without watchdog.
Jun 12 19:05:21 zigbee2mqtt pnpm[425]: [2025-06-12 19:05:21] debug: z2m: Removing old log directory ‘/opt/zigbee2mqtt/data/log/2025-06-12.19-03-27’
Jun 12 19:05:21 zigbee2mqtt pnpm[425]: [2025-06-12 19:05:21] info: z2m: Logging to console, file (filename: log.log)
Jun 12 19:05:21 zigbee2mqtt pnpm[425]: [2025-06-12 19:05:21] debug: z2m: Can’t load state from file /opt/zigbee2mqtt/data/state.json (doesn’t exist)
Jun 12 19:05:21 zigbee2mqtt pnpm[425]: [2025-06-12 19:05:21] info: z2m: Starting Zigbee2MQTT version 2.4.0 (commit #unknown)
Jun 12 19:05:21 zigbee2mqtt pnpm[425]: [2025-06-12 19:05:21] info: z2m: Starting zigbee-herdsman (4.1.0)
Jun 12 19:05:21 zigbee2mqtt pnpm[425]: [2025-06-12 19:05:21] debug: z2m: Using zigbee-herdsman with settings: ‘“{"network":{"panID":59915,"extendedPanID":[89,135,55,142,82,205,74,70],"channelList":[11],"networkKey":"HIDDEN"},"databasePath":"/opt/zigbee2mqtt/data/database.db","databaseBackupPath":"/opt/zigbee2mqtt/data/database.db.backup","backupPath":"/opt/zigbee2mqtt/data/coordinator_backup.json","serialPort":{"path":"/dev/ttyUSB0"},"adapter":{"disableLED":false}}”’
Jun 12 19:05:21 zigbee2mqtt pnpm[425]: [2025-06-12 19:05:21] debug: zh:adapter:discovery: Connected devices: [{“path”:“/dev/ttyS0”},{“path”:“/dev/ttyS1”},{“path”:“/dev/ttyS10”},{“path”:“/dev/ttyS11”},{“path”:“/dev/ttyS12”},{“path”:“/dev/ttyS13”},{“path”:“/dev/ttyS14”},{“path”:“/dev/ttyS15”},{“path”:“/dev/ttyS16”},{“path”:“/dev/ttyS17”},{“path”:“/dev/ttyS18”},{“path”:“/dev/ttyS19”},{“path”:“/dev/ttyS2”},{“path”:“/dev/ttyS20”},{“path”:“/dev/ttyS21”},{“path”:“/dev/ttyS22”},{“path”:“/dev/ttyS23”},{“path”:“/dev/ttyS24”},{“path”:“/dev/ttyS25”},{“path”:“/dev/ttyS26”},{“path”:“/dev/ttyS27”},{“path”:“/dev/ttyS28”},{“path”:“/dev/ttyS29”},{“path”:“/dev/ttyS3”},{“path”:“/dev/ttyS30”},{“path”:“/dev/ttyS31”},{“path”:“/dev/ttyS4”},{“path”:“/dev/ttyS5”},{“path”:“/dev/ttyS6”},{“path”:“/dev/ttyS7”},{“path”:“/dev/ttyS8”},{“path”:“/dev/ttyS9”},{“path”:“/dev/ttyUSB0”}]
Jun 12 19:05:21 zigbee2mqtt pnpm[425]: [2025-06-12 19:05:21] error: z2m: Error while starting zigbee-herdsman
Jun 12 19:05:21 zigbee2mqtt pnpm[425]: [2025-06-12 19:05:21] error: z2m: Failed to start zigbee-herdsman
Jun 12 19:05:21 zigbee2mqtt pnpm[425]: [2025-06-12 19:05:21] error: z2m: Check Zigbee2MQTT fails to start/crashes runtime | Zigbee2MQTT for possible solutions
Jun 12 19:05:21 zigbee2mqtt pnpm[425]: [2025-06-12 19:05:21] error: z2m: Exiting…
Jun 12 19:05:21 zigbee2mqtt pnpm[425]: [2025-06-12 19:05:21] error: z2m: Error: USB adapter discovery error (No valid USB adapter found). Specify valid ‘adapter’ and ‘port’ in your configuration.
I’l really stuck…
If someone could help.
Laurent
