Improve Shelly API integration
Hello !
Is there way to find which part of the Shelly API is included in the official Shelly integration ? Or which are planned to be added ? :slight_smile:
Common HTTP API โ€“ API Reference (shelly.cloud)
For instance, Iโ€™d like to be able to update the Night Mode settings of my Shelly dimmers. I can do it through http requests but this parameter is not availble using Shelly integration.
Or how could I contribute to add features available in Shelly API and not yet integrated ?
Thanks,
David
Source is here:
Thank you ! :slight_smile:
So Shelly integration uses CoIoT and not basic http.
I donโ€™t know much about it. : CoIoT Protocol โ€“ API Reference (shelly.cloud)
It does not look to allow as many things as basic http requests unfortunately (or maybe the documentation is not up-to-date). There is the same โ€˜problemโ€™ with MQTT integration. Not all parameters are available.
I wil try to play a little bit with CoIoT and see what is possible, but I guess what could be done has already been done !
And I will have to keep using http requests to enable/disable/configure my dimmer night modes ! :slight_smile:
