anyone updated to 115 ? seems after every restart, it discovers my velux again, when already running the custom
i cant ignore it it seems :
edit: already fixed, the custom was updated
yea i have the same issue, i have a lot of velux components
I tested the integration for a week now. so far so good, but one big pain point is the following:
When closing the cover(s), either via close_cover
or set_cover_position
with 0%, the covers do close, however some of them (but not all!) then open their tilt to 100% once the cover has reached the 0%/closed position.
All motors are identical (Somfy J4).
With the Tahoma integration, closing covers is not a problem at all.
Anyone else with this issue?
PS: I discovered that the closing/opening of tilt works as intended when using solely open_cover_tilt
(β> opens tilt) and close_cover_tilt
(β> closes tilt). Seems the close_cover
is kind of broken?
Hi, Iβm quite new to Home Assistant and trying to connect some somfy io shutters and an LED light via KLF200 from Velux.
Iβm using Home assistant via Docker in a Synology NAS.
Now I tried to add the custom integration for Velux but even it shows added in HACS I cannot find it on the integrations part to add it. Anything I missed to do?
Also itβs not installing the vellum folder under custom_components as it states.
thx in advance
Hello guy, anyone tried to use multiple KLF200 gateway?
Can you tell me if my_velux support two or more KLF200 at the same time?
