Got a bit further:
Tue Oct 30 2018 22:42:05 GMT+0100 (Central European Standard Time)
Error handling request
File "/usr/local/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 390, in start
resp = await self._request_handler(request)
File "/usr/local/lib/python3.6/site-packages/aiohttp/web_app.py", line 366, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.6/site-packages/aiohttp/web_middlewares.py", line 106, in impl
return await handler(request)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/static.py", line 66, in staticresource_middleware
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/real_ip.py", line 34, in real_ip_middleware
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/ban.py", line 66, in ban_middleware
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/auth.py", line 97, in auth_middleware
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/view.py", line 113, in handle
result = await result
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/config/core.py", line 21, in post
errors = await async_check_ha_config_file(request.app['hass'])
File "/usr/local/lib/python3.6/site-packages/homeassistant/config.py", line 796, in async_check_ha_config_file
check_ha_config_file, hass)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/scripts/check_config.py", line 372, in check_ha_config_file
platform = loader.get_platform(hass, domain, p_name)
File "/usr/local/lib/python3.6/site-packages/homeassistant/loader.py", line 60, in get_platform
return get_component(hass, PLATFORM_FORMAT.format(domain, platform))
File "/usr/local/lib/python3.6/site-packages/homeassistant/loader.py", line 92, in get_component
module = importlib.import_module(path)
File "/usr/local/lib/python3.6/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 994, in _gcd_import
File "<frozen importlib._bootstrap>", line 971, in _find_and_load
File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 678, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/config/custom_components/sensor/smartthinq_washer.py", line 42, in <module>
'INITIAL': wideq.STATE_WASHER_INITIAL,
AttributeError: module 'wideq' has no attribute 'STATE_WASHER_INITIAL'
I think it might have something to do with my wideq. How do I install it properly?
