Home Assistant shows an update is available for HA, ESPhome, along with each device. I update the first two, but now I am unable to update any of the devices. I have not changed the YAML code in months and it is still fully functional. This is the error I get:
INFO ESPHome 2024.12.4
INFO Reading configuration /config/esphome/wesp1.yaml...
ERROR Error while reading config: Invalid YAML syntax:
while parsing a block mapping
in "/config/esphome/wesp1.yaml", line 161, column 5
expected <block end>, but found '<block mapping start>'
in "/config/esphome/wesp1.yaml", line 169, column 6
This is the referenced area of code in the error, the first line is 161:
Indentation on “filters” and “unit_of_measurement” does not look right to me? Shouldn’t that be in the same column as icon? And you have “unit_of_measurement” twice
Moving the indent to where you suggest results in this error:
Duplicate key "unit_of_measurement"
in "/config/esphome/wesp1.yaml", line 171, column 5
NOTE: Previous declaration here:
in "/config/esphome/wesp1.yaml", line 167, column 5
Which the bottom portion is converting to Fahrenheit as changing unit of measurement above does not convert it in HA, just replaces the C with a F.
Removing the conversion/disabling(#) does make the code work, but results in it being in C again.
