In the above image, the Green check works consistently. I click the inject node with no data, and it fires the SetLEDEffect service call. The device behaves correctly.
I then copied the SetLEDEffect
and DisableLEDEffect
nodes down and made it occur after the yellow enableTimer
node. Now when the logic flows from enableTimer
into SetLEDEffect
, the exact same service call is made, but the end device does not reflect a changed behavior.
I went to the Developer Tools / Events tab and subscribed to the call_service
events. For the Green checkmark logic flow, I saw the event payload. For the red X logic flow, I also saw the event payload (to my surprise). The same payload (except the event context.id
and time_fired
fields, which are always unique). After confirming the events are correctly firing on the event bus, I’m at a loss.
Question: What would cause the event to be seen in the developer tools, but not make it to the device?
When I fire the exact same event payload using Developer Tools / Services tab, the device end behaves as expected. It only does not behave as expected when it is part of a longer flow as shown in the red X portion above.
