Inconsistent device reaction when using tuya bulbs, pi-hole and matterhub addon
Hello guys,
I am using several lightbulbs with the tuya integration and a few one from Philipps Hue in my home. I have a lamp which contains 4 tuya-bulbs and I combined them in a helper.
A few weeks ago I started to use the Matter-Hub-Addon from t0bst4r to control my bulbs with Alexa. It worked really well and the bullbs went on/off at the same time.
A few days ago I set up a RaspberyPi3 with pi-hole on it. (local dns to block ads in my network). All in all it works pretty well. Except for my tuya bulbs…
When I control a single bulb, it’s reaction speed is okay. But when I control a group of bulbs (for example a room or a helper group), it responds sometimes a few minutes ago, just one singe bulb reacts (the others follow 30 seconds later) or even nothing happens.
In the log of the matterhub-addon it says:
2025-04-09 07:37:14.639 INFO   BehaviorServer       Invoke a74c9b17e1904951ac3728d7923a1335.aggregator.light_flur_2.on online#d2c749@41510c0dbdefe61 (no payload)
2025-04-09 07:37:14.661 INFO   BehaviorServer       Invoke a74c9b17e1904951ac3728d7923a1335.aggregator.light_flur_1.on online#d2c74b@41510c0dbdefe61 (no payload)
2025-04-09 07:37:14.668 INFO   BehaviorServer       Invoke a74c9b17e1904951ac3728d7923a1335.aggregator.light_flur_4.on online#e8665c5@41510c0f39c3091 (no payload)
2025-04-09 07:37:14.678 INFO   BehaviorServer       Invoke a74c9b17e1904951ac3728d7923a1335.aggregator.light_flur_3.on online#d2c74d@41510c0dbdefe61 (no payload)
But this shows also up in the log when I control my philips hue devices, which works fine.
In my pi-hole query logs I can see the tuya requests:
I’m really confused why this happens and it’s pretty annoying.
Does anyone have an idea what the reason and a fix for that could be?
Thank you!
Hello Vygrox,
My suggestion, eliminate all man-in-the-middle DNS Blocker programs. You likely have it set-up wrong and it is doing what it is designed to do,which is block DNS. I’m talking PiHole or Adguard…
Solution:
I switched to the HACS-addon local tuya and added all my devices manually with the developer api in my homassistant. Now it works really fast even when I want to change the color on a helper group with a few bulbs.
Thanks.
