Set channel it to 15 , PanID to 1 and the network key to the original (need to change later). Do this in both the add-on configuration and in the configuration.yaml file… Delete the backup file “configuration.yaml.bk” in the zigbee2mqtt directory, Restart Z2M and lets see the logs
You serial-port look right now.
Here is my configuration.yaml, corrected into the standard network key.
Happy it works. Mine is running on channel 13. But no reason to change away from 11 if it works.
If you would like to change the network key, remember to do so before you have paired a lot of devices. You need to re/pair after changing network key. Once again, remember to remove the .bk file, otherwise it will not change.
Strange. I have a “configuration.yaml.bk”, and documentation says it should be deleted if changes are made. Maybe not valid anymore after version 1.25? Not sure.
So I have been adding zigbee end devices and connected ingredients them through the routers. Now that I want to move the location of some of the end devices, and they become far away from their original router device. So is there a way to move their ‘connection’ from one router and connect it through another router?
Or do I have have to remove the end devices from the zigbee network and pair again?
Typically, you can pair them again without removing them first (turn on “Permit join” in z2m and put the device in pairing mode). That way, z2m will reuse the information it already knows about the device.
