Incorrect time zone
I noticed that my HA instance on Proxmox is showing the wrong time—specifically, it’s one hour behind. In the HA system settings, it shows Rome +1 instead of +2. This seems to be a known issue; does anyone have a solution? Thanks.
You can’t change it under Settings → Home Information → Region?
It’s correct & not an issue. I live in the same timezone as Rome & it also shows+1 for me due to Daylight Savings Time (Summer Time). If you look at your sensor timestamps, you will see that HA shows the additional hour correctly in the frontend. Read here for a similar topic on the subject [Solved] Bad timezone / daylight saving time
I solved it by setting the timezone in my IP camera settings
