I’m using Life360 as Presense Detection to switch on lights after sunset when I arrive home.
The slow update rate of the entity means that often I’m home for a minute or two before HA recognises the fact and turns the lights on.
Is there a way of increasing the scan rate of that one entity to more like 15 seconds?
I am aware that Life360 itself is updating quicker than HA by viewing the scan rate within their own Life360 app on my mobile phone.
There is a parameter called interval_seconds
which can only be set by adding the life 360 integration through configuration.yaml. Please see life360 docs
This might help but I have seen that in iphones even with this value set to lowest, the update happens slower. But in android there is not so much delay.
Thanks, I’ll take a look.
