Increment counter based on another counter
I’m having a points system for chores in the family. I want to introduce a weekly total sum, so I created a new “weekly points” counter helper for each family member. I want to create an automation that adds the value of the daily counter “daily points” to the “weekly points” counter.
Does anyone have an idea how this could be done?
Use a Utility Meter helper.
Could you explain more how this would work? I haven’t used a utility helper before, but looking at it now, I can’t see how that would help? The Input sensor has to be of domain sensor, so it can’t be a counter.
I had forgotten that fact… :slight_smile:
You haven’t stated whether the weekly total’s value needs to increment immediately when you add to the daily value or whether there will be a need to decrement the weekly value. For a basic version that updates the weekly total at the end of the day, you can use an automation with a template in the counter.configure service call:
  - platform: time
    at: "23:59:00"
condition: []
  - choose:
    - conditions:
        - "{{ now().isoweekday() == 7 }}"
      sequence:
        - service: counter.configure
            value: 0
            entity_id: counter.weekly_points
    default:
            value: >-
              {{ states('counter.weekly_points') | int(0)
              + states('counter.daily_points') | int(0) }}
Depending on your use case, you may still want to use a Utility Meter. For that you would first create a Template sensor that mirrors the value of your counter.
template:
  - sensor:
    - name: Chore Points Counter Mirror
      state: "{{ states('counter.daily_points') }}"
Then, in the UI, you would create your utility meter sensor(s).
That seems to have made the trick! Thanks!
