Increment input_number value with a sensor attribute via automation
I’m trying to get a total from a sensor’s attribute.
Every time this sensor receives a new state/attribute it would add the attribute’s number to the a input number and then give me a total.
Would it be possible?
I tried this but doesn’t work, pretty sure my code ain’t right.
description: ""
mode: single
  - platform: state
    entity_id:
      - sensor.baby_last_feed
condition: []
  - service: input_number.set_value
    metadata: {}
      value: {state_attr('sensor.baby_last_feed', 'amount') + states('input_number.clem_total_feed')}
      entity_id: input_number.clem_total_feed
The template syntax is incorrect and it attempts to add a string value (must be converted to a number).
      value: "{{ state_attr('sensor.baby_last_feed', 'amount') | int(0) + states('input_number.clem_total_feed') | int(0) }}"
The value of the amount attribute may already be a number so the first int(0) may be unnecessary. However the state value of all entities, including an Input Number, is a string and must be converted to a number before performing any arithmetic operations (so the second int(0) is required).
A template appearing on the same line as the YAML option should be wrapped in quotes.
Reference
Important Templating Rules
My hero, it works, thank you very much!
