I am confused as to the rules for indentation
For the following the indenation of the options must be the same level as the tag
- platform: gpio
name: "Water Solenoid ${solenoidname}"
pin: GPIO${solenoidpin}
Adding the indent gives this error
INFO ESPHome 2025.12.5
INFO Reading configuration /config/esphome/esphome-web-2e8530.yaml…
ERROR Error while reading config: Invalid YAML syntax:mapping values are not allowed here
in “/config/esphome/.solenoidboardwithparams.yaml”, line 37, column 13
Yet for the following the indentation of the options must be one level up from the tag
- logger.log:
tag: ${solenoidname}
format: "ID is %i not ${sectionid}"
args: ['id(currentsolenoid)']
level: debug
Removing the indent gives this error
while parsing a block collection
in “/config/esphome/.solenoidboardwithparams.yaml”, line 69, column 33
expected , but found ‘?’
in “/config/esphome/.solenoidboardwithparams.yaml”, line 70, column 33
I am fairly new - and I’m slowly getting used to the system but when I move code around and it requires re-indentation this above threw me and I dont see an obvious difference between the two cases - the first one seems to me that it should be indented
