Influx DB automatically disconnected after some hours
Hi, after the last HA update Influx DB is lossing the connection after some hours of working fine.
Any idea? I’m the only one is having these issues?
Many thanks to all the community of HA is amazing these project!
ERROR (influxdb) [homeassistant.components.influxdb] Cannot connect to InfluxDB due to 'HTTPConnectionPool(host='192.1XXX.X.XXX', port=8086): Max retries exceeded with url: /write?db=ha_influx_db (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f2992e04700>: Failed to establish a new connection: [Errno 111] Connection refused'))'. Please check that the provided connection details (host, port, etc.) are correct and that your InfluxDB server is running and accessible.
I have this too… :roll_eyes:
Did you find any reason/solution?
Hi Nick, I deleted, reboot, reintalled and reboot. All updated and worked!
Hi, I had this problem multiple times and that’s what I did too since I didn’t find any reason/solution to avoid this.
With
Every time I lost data, which is not the end of the world but not what I want.
I was making backups - not often enough - of the whole machine but now I have found a way to offload only the database.
