Influx not receiving data
Has anyone successfully managed to get EmonCMS feed data into a Homeassistant InfluxDB ? I’ve followed all the guides all I can say is the feeds are good, Homeassistant has the correct yaml entries, Influx is set up and HA connects to the DB fine, permissions are set on the db but still no data flows from the feeds. I’m wondering if there are undocumented set up steps
Let’s go bottom-up, as there is so few factual details.
How did you confirm / test those 2 assertions?
From the home-assistant.log.
  1. I deliberately changed the connection details and an error was recorded, I reverted and there was none.
  2. I ran SQL on the Influx database ‘homeassistant’ and no results were returned (and no errors)
