Hi Everyone,
Been trying to setup a sensor in home assistant from InfluxDB 2 and IOTAWATT ( I dont want to use the IOTAWAT integration as the polling is causing issues)
Please see attached the error I get in the YAML checker and also the code snippets.
Any assistance is greatly appreciated
#IOTAWATT INFLUXDB DATABASE
influxdb:
host: 192
api_version: 2
port: 8086
ssl: false
organization: c
token: 6
bucket: iotawatt
exclude:
entity_globs: "*"
##########INFLUXDB
- platform: influxdb
api_version: 2
organization: c
token: V
bucket: iotawatt
queries_flux:
- name: "Solar_HA_IDB"
query: >
filter(fn: (r) => r["_measurement"] == "iotawatt")
|> filter(fn: (r) => r["_field"] == "Watts")
|> filter(fn: (r) => r["input"] == "Solar_HA")
|> last(column: "_value")
|> keep(columns: ["_value"])
- range_start: "-7d"
group_function: last
I have also tried what is in the documentation InfluxDB - Home Assistant
filter(fn: (r) => r._measurement == "iotawatt" and r._field == "Watts" and r.input == "Solar_HA")
With the same results as the image above.
The only time I got the error to go away was when I had filter in the same indentation as query: > but that throws a different error of filter not existing under “queries_flux” obviously.
