InfluxDB 2 - use only to populate sensors
I would like to use InfluxDB integration only to populate the sensors using data from the database.
My configuration:
influxdb:
  exclude:
    entity_globs: "*"
  - platform: influxdb
    api_version: 2
    ssl: true
    host: xx
    port: xx
    token: xx
    organization: xx
    bucket: xx
    queries_flux:
      - name: Temperature
        query: >
          filter(fn: (r) =>
            r._measurement == "xx" and
            r.station_id == "xx" and
            r._field == "temperature")
          |> last()
          |> keep(columns: ["_value"])
        unit_of_measurement: °C
        value_template: "{{ value | round(2) }}"
However, I can see in the logs that the integration is constantly trying to connect to local InfluxDB instance to write data, even though all entites are excluded. Moreover, I am using read only token.
Is it possible to disable the write functionality of the integration and use only the queries to populate sensors states?
I have almost the same config and I also have the same issue for a few years now. Does anyone have an idea on how to configure this better?
