InfluxDB 3.6.2 installation issue
I’ve had the InfluxDB add on within Home Assistant for some time but apart from upgrading it occasionally haven’t really used it. This afternoon in upgrading from 3.5.1 to 3.6.2 I got the error “Failed to install addon, Unknown Error, see logs”. The following was in the Supervisor log. Has anybody else seen this?
I have recently (Monday) moved from a rPi3 to a NUC (Ubuntu/Virtualbox) and restored a snapshot. Everything else seems to be working fine although getting zwave stick to present itself to virtualbox was challenging. I’ve tried uninstalling InfluxDB and reinstalling and get the same issue. Other add ons can be installed without issue. Any ideas?
Cheers Doug
I noticed that I was also getting ‘database disk image is malformed’ errors periodically in the Core log. Deleted the home-assistant_v2.db file and restarted home assistant. This resolved those errors and the InfluxDB installation issue. :slight_smile:
Iam also facing the same issue…
I can confirm that. Same problem, same solution.
