Hi
Does anyone uses this software on the one, same Raspberry Pi?
I wonder about efficiency of RPi and SD card storage.
Hi
I have most of this on a server not a Pi. It works well and can’t say it’s having a major impact on resources.
Now I have no idea how it would behave on a Pi, but depending on what you save in InfluxDB, you’ll end up with 2 DBs and whereas the Pi might handle, I’m not sure your sd card will like it long term…
Yes. I had this on a RP3, and it was all great until it wasn’t! I’m not sure if it was due to SD card issues or due to unclean power off issue corrupting card, but it ended up a right mess. No UI visible, access through homekit worked most of the time, DNS was sporadic.
Apart from the card issue the Pi handled it well, load usually <20% unless updating.
I have set it up again but without influxdb, and am looking to move to a SSD at some point, or maybe an odroid C2 with emmc flash.
