Influxdb setup for electricity & temp
I setup influxdb & grafana when I installed HA years ago.
I’ve never used them. Now it’s just filling up the DB, I want to set it properly.
I have solar from solar analytics.yaml
I have temp/humidity sensors in each room
I have a few power plugs with monitors
I think that’s all I really want recorded.
In influxdb I changed to
include:
  entities:
    - sensor.sa_mer_percentage
  entity_globs:
    - sensor.*humidity
    - sensor.*temperature
    - sensor.sa_todays_energy*
    - sensor.sa_data_by_5min_energy*
    - sensor.sa_live_site_data*
Maybe what I want are W(atts)
Wh
C (deg)
% (humidity)
Then, how do I:
  1. delete all other data I’ve saved these 2 years from the db
  2. or just delete the whole db and start again?
I found a better way to clean up
use homeassistant; drop measurement "mm"
Seems to remove the index too
Half the time error 504 tho
Also regex isn’t same as sql - why keep making so many similar standards?
use homeassistant; delete from "%" where entity_id =~ /.*battery$/
