I am having some trouble with a new setup of InfluxDB running on a remote server.
I have setup Influx on a remote nix vm, and created the database home_assistant. My configuration files are as follows
influxdb: !include homeassistant/influxdb/influxdb.yaml
host: monitor1
port: 8086
database: home_assistant
I am getting the following errors on start up. Can anyone please assist?
16-12-22 19:21:53 homeassistant.bootstrap: Error during setup of component influxdb
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 138, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/util/connection.py", line 75, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/lib/python3.4/socket.py", line 530, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -2] Name or service not known
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 594, in urlopen
chunked=chunked)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 361, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/lib/python3.4/http/client.py", line 1090, in request
self._send_request(method, url, body, headers)
File "/usr/lib/python3.4/http/client.py", line 1128, in _send_request
self.endheaders(body)
File "/usr/lib/python3.4/http/client.py", line 1086, in endheaders
self._send_output(message_body)
File "/usr/lib/python3.4/http/client.py", line 924, in _send_output
self.send(msg)
File "/usr/lib/python3.4/http/client.py", line 859, in send
self.connect()
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 163, in connect
conn = self._new_conn()
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 147, in _new_conn
self, "Failed to establish a new connection: %s" % e)
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.HTTPConnection object at 0x6f6d4c90>: Failed to establish a new connection: [Errno -2] Name or service not known
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/adapters.py", line 423, in send
timeout=timeout
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 643, in urlopen
_stacktrace=sys.exc_info()[2])
File "/srv/hass/hass_venv/lib/python3.4/site-packages/requests/packages/urllib3/util/retry.py", line 363, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
requests.packages.urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='monitor1', port=8086): Max retries exceeded with url: /query?db=home_assistant&q=select+%2A+from+%2F.%2A%2F+LIMIT+1%3B (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x6f6d4c90>: Failed to establish a new connection: [Errno -2] Name or service not known',))
Cheers
Zak
