Initial Atom Echo S3R impressions and optimizing the wake word config
Hi everyone,
I recently picked up one of these over the holidays
It differs from the other echo model in two major ways:
  • No RGB LED (there is a green one behind the reset button, but it isn’t exposed via pins to the esp32 as far as I can tell)
  • Much larger PSRAM
The lack of LED means a typical voice pipeline now needs to issue some sort of ping/ding or sound to let the user know when the wake word is heard. Esphome has some great options in the components for this. Overall, really good, with some minor quirks I’m documenting here so we can continue improving voice.
The Echo S3R only has one I2S bus (not two like the Voice PE). This means the device "walkie talkie"s with the speaker and microphone taking turns on the bus. The public yaml for this device (esphome-yaml/common/atom-echos3r-satellite-base.yaml at 2fd326380b3ee362ddeaa0f101b1a77c195bd393 · m5stack/esphome-yaml · GitHub) works, but has some quirks. It’s easy enough to play a sound over the I2S bus to a speaker in the “on_wake_word_detected” section, but we need to clear the bus before it gets re-occupied by the next call to voice_assistant.start (which uses the bus for microphone in the STT step). If we don’t clear the bus after playing the sound, the voice_assistant component will retry occupying the bus every 1 second (which is way too long for interactive voice commands). The public yaml tries to play a ding sound, followed by a 300ms delay, which may or may not be long enough to clear the bus.
A more reliable option to get this all working smoothly is to forcibly stop the media_player and the speaker in rapid succession and waiting for the bus to clear as part of the micro_wake_word component. This lets the voice_assistant component start capturing audio for STT very quickly after the wake word ding. We also get the chance to simply drop audio that’s too long. The ding from the Voice PE project is 1 second long by default. This config trims it to 250ms, and feels much more natural in my testing.
  on_wake_word_detected:
    - script.execute:
        priority: true
        sound_file: !lambda return id(wake_word_triggered_sound);
    - delay: 250ms
    - media_player.stop:
    - speaker.stop:
    - wait_until:
        condition:
          speaker.is_stopped: i2s_speaker
    - voice_assistant.start:
        wake_word: !lambda return wake_word;
My testing also revealed that this won’t work within the “on_wake_word_detected” option within the voice_assistant component itself. It seemed like stopping either the microphone or speaker while inside the voice_assistant pipe resulted in the pipe stopping itself. This means this wake word ding config only works with on-device microwakewords.
Overall, really fun project, with a nice new device.
Hi @afloat5271 I’m so glad I found your topic!
I too picked up an Atom Echo S3R over the holidays but have not had the same success you have had in getting it working.
Would you mind sharing your complete YAML file including your changes in this thread please?
Sure! Here ya go. Please note that I’m using a custom “hey tater” wake word.
substitutions:
  # Phases of the Voice Assistant
  # The voice assistant is ready to be triggered by a wake word
  voice_assist_idle_phase_id: "1"
  # The voice assistant is listening for a voice command
  voice_assist_listening_phase_id: "2"
  # The voice assistant is currently processing the command
  voice_assist_thinking_phase_id: "3"
  # The voice assistant is replying to the command
  voice_assist_replying_phase_id: "4"
  # The voice assistant is not ready
  voice_assist_not_ready_phase_id: "10"
  # The voice assistant encountered an error
  voice_assist_error_phase_id: "11"
  # Muted phase
  voice_assist_muted_phase_id: "12"
  # Finished timer phase
  voice_assist_timer_finished_phase_id: "20"
esphome:
  friendly_name: m5echos3r
  on_boot:
    - priority: 600
      then:
        - delay: 30s
        - if:
            condition:
              lambda: return id(init_in_progress);
            then:
              - lambda: id(init_in_progress) = false;
    - priority: -100
      then:
        media_player.speaker.play_on_device_media_file:
          media_file: wake_word_triggered_sound
          announcement: false
# Enable logging
logger:
  #level: VERBOSE
# Enable Home Assistant API
api:
  encryption:
    key: ""
ota:
  - platform: esphome
    password: ""
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "M5Echos3R Fallback Hotspot"
    password: ""
esp32:
  board: esp32s3box
  flash_size: 8MB
  cpu_frequency: 240MHz
  framework:
    type: esp-idf
    ## Note: Disable these configurations if you face the boot loop issue.
    sdkconfig_options:
        CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
        CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
        CONFIG_ESP32S3_INSTRUCTION_CACHE_32KB: "y"
        # Moves instructions and read only data from flash into PSRAM on boot.
        # Both enabled allows instructions to execute while a flash operation is in progress without needing to be placed in IRAM.
        # Considerably speeds up mWW at the cost of using more PSRAM.
        CONFIG_SPIRAM_RODATA: "y"
        CONFIG_SPIRAM_FETCH_INSTRUCTIONS: "y"
        CONFIG_BT_ALLOCATION_FROM_SPIRAM_FIRST: "y"
        CONFIG_BT_BLE_DYNAMIC_ENV_MEMORY: "y"
        CONFIG_MBEDTLS_EXTERNAL_MEM_ALLOC: "y"
        CONFIG_MBEDTLS_SSL_PROTO_TLS1_3: "y"  # TLS1.3 support isn't enabled by default in IDF 5.1.5
psram:
  mode: octal
  speed: 80MHz
button:
  - platform: factory_reset
    internal: true
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO41
      mode: INPUT_PULLUP
      inverted: true
    internal: true
    on_multi_click:
      - timing:
          - ON for at least 50ms
          - OFF for at least 50ms
        then:
          - switch.turn_off: timer_ringing
      - timing:
          - ON for at least 10s
        then:
          - button.press: factory_reset_btn
# I2C Bus Configuration
i2c:
  sda: GPIO45
  scl: GPIO0
  scan: false
# I2S Bus Configuration
i2s_audio:
  - id: i2s_audio_bus
    i2s_lrclk_pin: GPIO3
    i2s_bclk_pin: GPIO17
    i2s_mclk_pin: GPIO11
audio_dac:
  - platform: es8311
    bits_per_sample: 16bit
    sample_rate: 48000
microphone:
  - platform: i2s_audio
    sample_rate: 16000
    i2s_din_pin: GPIO4
    adc_type: external
speaker:
    i2s_dout_pin: GPIO48
    dac_type: external
    sample_rate: 48000
    channel: left
    audio_dac: es8311_dac
    buffer_duration: 100ms
media_player:
  - platform: speaker
    volume_min: 0.5
    volume_max: 0.8
    announcement_pipeline:
      speaker: i2s_speaker
      format: FLAC
      sample_rate: 48000
      num_channels: 1  # Atom Echo S3R only has one output channel
    files:
      - id: wake_word_triggered_sound
        file: https://github.com/esphome/home-assistant-voice-pe/raw/dev/sounds/wake_word_triggered.flac
      - id: timer_finished_sound
        file: https://github.com/esphome/home-assistant-voice-pe/raw/dev/sounds/timer_finished.flac
      - id: error_cloud_expired
        file: https://github.com/esphome/home-assistant-voice-pe/raw/dev/sounds/error_cloud_expired.mp3
    on_announcement:
      # Stop the wake word (mWW or VA) if the mic is capturing
      - if:
          condition:
            - microphone.is_capturing:
          then:
            - script.execute: stop_wake_word
            # Ensure VA stops before moving on
            - if:
                condition:
                  - lambda: return id(wake_word_engine_location).state == "In Home Assistant";
                then:
                  - wait_until:
                      - not:
                          voice_assistant.is_running:
      # Since VA isn't running, this is user-intiated media playback. Draw the mute display
      - if:
          condition:
            not:
          then:
            - lambda: id(voice_assistant_phase) = ${voice_assist_muted_phase_id};
    on_idle:
      # Since VA isn't running, this is the end of user-intiated media playback. Restart the wake word.
      - if:
          condition:
            not:
          then:
            - script.execute: start_wake_word
            - script.execute: set_idle_or_mute_phase
micro_wake_word:
  microphone: i2s_mic
  stop_after_detection: false
  models:
    - model: https://github.com/TaterTotterson/microWakeWords/raw/main/microWakeWords/hey_tater.json
    - model: https://github.com/kahrendt/microWakeWord/releases/download/stop/stop.json
      internal: true
  vad:
    - script.execute:
        priority: true
    - delay: 250ms
    - speaker.stop:
    - wait_until:
        condition:
voice_assistant:
  microphone: i2s_mic
  media_player: speaker_media_player
  micro_wake_word: mww
  use_wake_word: false
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 2.0
  on_listening:
    - lambda: id(voice_assistant_phase) = ${voice_assist_listening_phase_id};
  on_stt_vad_end:
    - lambda: id(voice_assistant_phase) = ${voice_assist_thinking_phase_id};
  on_tts_start:
    - lambda: id(voice_assistant_phase) = ${voice_assist_replying_phase_id};
  on_end:
    # Wait a short amount of time to see if an announcement starts
    - wait_until:
        condition:
          - media_player.is_announcing:
        timeout: 0.5s
    # Announcement is finished and the I2S bus is free
    - wait_until:
        - and:
            - not:
            - not:
                speaker.is_playing:
    # Restart only mWW if enabled; streaming wake words automatically restart
    - if:
        condition:
          - lambda: return id(wake_word_engine_location).state == "On device";
        then:
          - lambda: id(va).set_use_wake_word(false);
          - micro_wake_word.start:
  on_error:
    # Only set the error phase if the error code is different than duplicate_wake_up_detected or stt-no-text-recognized
    # These two are ignored for a better user experience
    - if:
        condition:
          and:
            - lambda: return !id(init_in_progress);
            - lambda: return code != "duplicate_wake_up_detected";
            - lambda: return code != "stt-no-text-recognized";
        then:
          - lambda: id(voice_assistant_phase) = ${voice_assist_error_phase_id};
          - delay: 1s
          - if:
              condition:
                switch.is_off: mute
              then:
                - lambda: id(voice_assistant_phase) = ${voice_assist_idle_phase_id};
              else:
        # If the error code is cloud-auth-failed, serve a local audio file guiding the user.
    - if:
        condition:
          - lambda: return code == "cloud-auth-failed";
        then:
          - script.execute:
              priority: true
              sound_file: !lambda return id(error_cloud_expired);
  on_client_connected:
  on_client_disconnected:
    - lambda: id(voice_assistant_phase) = ${voice_assist_not_ready_phase_id};
  on_timer_finished:
    - switch.turn_on: timer_ringing
    - wait_until:
    - lambda: id(voice_assistant_phase) = ${voice_assist_timer_finished_phase_id};
script:
  # Starts either mWW or the streaming wake word, depending on the configured location
  - id: start_wake_word
    then:
      - if:
          condition:
            and:
              - not:
                  - voice_assistant.is_running:
          then:
      - if:
          condition:
            and:
              - not:
          then:
            - lambda: id(va).set_use_wake_word(true);
            - voice_assistant.start_continuous:
  # Stops either mWW or the streaming wake word, depending on the configured location
  - id: stop_wake_word
    then:
      - if:
          condition:
          then:
            - voice_assistant.stop:
      - if:
          condition:
          then:
            - micro_wake_word.stop:
  # Set the voice assistant phase to idle or muted, depending on if the software mute switch is activated
  - id: set_idle_or_mute_phase
    then:
      - if:
          condition:
            switch.is_off: mute
          then:
          else:
  - id: play_sound
    parameters:
      priority: bool
      sound_file: "audio::AudioFile*"
    then:
      - lambda: |-
          if (priority) {
            id(speaker_media_player)
              ->make_call()
              .set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_STOP)
              .set_announcement(true)
              .perform();
          if ( (id(speaker_media_player).state != media_player::MediaPlayerState::MEDIA_PLAYER_STATE_ANNOUNCING ) || priority) {
              ->play_file(sound_file, true, false);
switch:
  - platform: gpio
    pin: GPIO18
    restore_mode: RESTORE_DEFAULT_ON
    entity_category: config
    disabled_by_default: true
    internal: true
    icon: "mdi:microphone-off"
    optimistic: true
    restore_mode: RESTORE_DEFAULT_OFF
    on_turn_off:
      - microphone.unmute:
    on_turn_on:
      - microphone.mute:
    optimistic: true
    internal: true
    restore_mode: ALWAYS_OFF
    on_turn_off:
      # Turn off the repeat mode and disable the pause between playlist items
      - lambda: |-
                ->make_call()
                .set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_REPEAT_OFF)
                .perform();
              id(speaker_media_player)->set_playlist_delay_ms(speaker::AudioPipelineType::ANNOUNCEMENT, 0);
      # Stop playing the alarm
          announcement: true
    on_turn_on:
      # Turn on the repeat mode and pause for 1000 ms between playlist items/repeats
      - lambda: |-
              ->make_call()
              .set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_REPEAT_ONE)
              .perform();
            id(speaker_media_player)->set_playlist_delay_ms(speaker::AudioPipelineType::ANNOUNCEMENT, 1000);
      - media_player.speaker.play_on_device_media_file:
          media_file: timer_finished_sound
          announcement: true
      - delay: 15min
select:
    name: Wake word engine location
    icon: "mdi:account-voice"
    optimistic: true
    restore_value: true
    options:
      - In Home Assistant
      - On device
    initial_option: On device
    on_value:
      - if:
          condition:
          then:
            - wait_until:
                lambda: return id(voice_assistant_phase) == ${voice_assist_muted_phase_id} || id(voice_assistant_phase) == ${voice_assist_idle_phase_id};
            - if:
                condition:
                  lambda: return x == "In Home Assistant";
                then:
                  - delay: 500ms
                  - if:
                      condition:
                        switch.is_off: mute
                      then:
            - if:
                condition:
                  lambda: return x == "On device";
                then:
                  - delay: 500ms
                  - if:
                      condition:
                        switch.is_off: mute
                      then:
    name: "Wake word sensitivity"
    optimistic: true
    initial_option: Slightly sensitive
    restore_value: true
    options:
      - Slightly sensitive
      - Moderately sensitive
      - Very sensitive
    on_value:
      # Sets specific wake word probabilities computed for each particular model
      # Note probability cutoffs are set as a quantized uint8 value, each comment has the corresponding floating point cutoff
      # False Accepts per Hour values are tested against all units and channels from the Dinner Party Corpus.
      # These cutoffs apply only to the specific models included in the firmware: [email protected], hey_jarvis@v2, hey_mycroft@v2
      lambda: |-
        if (x == "Slightly sensitive") {
          id(hey_tater).set_probability_cutoff(250);   // 0.97 -> 0.563 FAPH on DipCo (Manifest's default)
        } else if (x == "Moderately sensitive") {
          id(hey_tater).set_probability_cutoff(245);   // 0.92 -> 0.939 FAPH on DipCo
        } else if (x == "Very sensitive") {
          id(hey_tater).set_probability_cutoff(222);   // 0.83 -> 1.502 FAPH on DipCo
globals:
  - id: init_in_progress
    type: bool
    restore_value: false
    initial_value: "true"
  - id: voice_assistant_phase
    type: int
    initial_value: ${voice_assist_not_ready_phase_id}
Hey, I just got my EchoS3R. I tried the stock config, and it didn’t work.
And I just found yours and tried it too, and the same happens.
I only changed the model to Alexa instead, as I find that’s the easiest recognisable one.
When I call it, I can hear the sound, and that’s it. The HA entity doesn’t change to “listening”, and it won’t react to commands. Also, it doesn’t matter how long I wait, it won’t react to a second call after a while either. It gets stuck somehow.
Here are the logs:
[10:53:03][D][api.connection:2221]: Home Assistant 2026.1.3 (192.168.1.158): connected
[10:53:03][W][micro_wake_word:356]: Wake word detection is already running
[10:53:28][D][micro_wake_word:325]: Detected 'Alexa' with sliding average probability is 0.61 and max probability is 1.00
[10:53:28][D][media_player:084]: 'm5echos3r' - Setting
[10:53:28][D][media_player:088]:   Command: STOP
[10:53:28][D][media_player:097]:  Announcement: yes
[10:53:28][D][micro_wake_word:370]: Stopping wake word detection
[10:53:28][D][micro_wake_word:378]: State changed from DETECTING_WAKE_WORD to STOPPING
[10:53:28][D][speaker_media_player:410]: State changed to ANNOUNCING
[10:53:28][D][micro_wake_word:274]: Inference task is stopping, deallocating buffers
[10:53:28][D][micro_wake_word:279]: Inference task is finished, freeing task resources
[10:53:28][D][micro_wake_word:378]: State changed from STOPPING to STOPPED
[10:53:28][D][speaker_media_player.pipeline:114]: Reading FLAC file type
[10:53:28][D][ring_buffer:034][ann_read]: Created ring buffer with size 1000000
[10:53:28][D][speaker_media_player.pipeline:124]: Decoded audio has 1 channels, 48000 Hz sample rate, and 16 bits per sample
[10:53:28][D][i2s_audio.speaker:102]: Starting
[10:53:28][D][i2s_audio.speaker:106]: Started
[10:53:28][D][ring_buffer:034][speaker_task]: Created ring buffer with size 9600
[10:53:28][D][media_player:097]:  Announcement: no
[10:53:28][D][i2s_audio.speaker:111]: Stopping
[10:53:28][D][i2s_audio.speaker:116]: Stopped
[10:53:28][D][voice_assistant:482]: State changed from IDLE to START_MICROPHONE
[10:53:28][D][voice_assistant:489]: Desired state set to START_PIPELINE
[10:53:28][D][voice_assistant:208]: Starting Microphone
[10:53:28][D][ring_buffer:034]: Created ring buffer with size 16384
[10:53:28][D][voice_assistant:482]: State changed from START_MICROPHONE to STARTING_MICROPHONE
[10:53:28][D][speaker_media_player:410]: State changed to IDLE
[10:53:28][D][voice_assistant:482]: State changed from STARTING_MICROPHONE to START_PIPELINE
[10:53:28][D][voice_assistant:229]: Requesting start
[10:53:28][D][voice_assistant:482]: State changed from START_PIPELINE to STARTING_PIPELINE
[10:53:28][D][voice_assistant:504]: Client started, streaming microphone
[10:53:28][D][voice_assistant:482]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[10:53:28][D][voice_assistant:489]: Desired state set to STREAMING_MICROPHONE
Is this not happening to yours? It’s very strange, given that it’s the stock config.
I’ve also been asking in Discord and got no help.
Is the s3r the first device you’ve tried to set up for voice assist or do you have other devices that are already hooked up and working?
I built an ESP32 with a Mic, without speaker. And I managed to get that working (without responses ofc). But the assistant worked and performed actions fine.
It was a way more basic setup, and tbh I prefer it as I understand more for debugging.
I have been trying using that file just changing pins, and keeping the essentials.
Again I get some logs detecting the word, but the assistant doesn’t switch to listening mode. Not sure why. It was def working with the ESP32 (don’t have it anymore to try again).
I’ll post the config later and logs when on my PC.
Edit:
esphome:
  friendly_name: EchoS3R VA
# Includes logger, api, ota, wifi, captive_portal, and reset buttons
packages:
  - !include common/base.yaml
esp32:
  board: esp32s3box
  framework:
    type: esp-idf
api:
    then:
      - delay: 50ms
    then:
i2s_audio:
  - id: i2s_audio_bus
    i2s_lrclk_pin: GPIO3 # WS
    i2s_bclk_pin: GPIO17 # SCK
    i2s_mclk_pin: GPIO11 # MCLK
microphone:
    i2s_audio_id: i2s_audio_bus
    adc_type: external
    i2s_din_pin: GPIO4 # SD
micro_wake_word:
  models:
    - model: alexa
      probability_cutoff: 0.6
voice_assistant:
  microphone: i2s_mic
  on_error:
  on_end:
    then:
      - wait_until:
          not:
switch:
    optimistic: true
    on_turn_off:
    on_turn_on:
Logs when I call the wake word (only once, then nothing, but it reacts again after toggling the mute switch):
[20:03:37.495][D][micro_wake_word:325]: Detected 'Alexa' with sliding average probability is 0.72 and max probability is 1.00
[20:03:37.504][D][voice_assistant:482]: State changed from IDLE to START_MICROPHONE
[20:03:37.504][D][voice_assistant:489]: Desired state set to START_PIPELINE
[20:03:37.506][D][micro_wake_word:370]: Stopping wake word detection
[20:03:37.507][D][voice_assistant:208]: Starting Microphone
[20:03:37.507][D][ring_buffer:034]: Created ring buffer with size 16384
[20:03:37.529][D][voice_assistant:482]: State changed from START_MICROPHONE to STARTING_MICROPHONE
[20:03:37.529][D][micro_wake_word:378]: State changed from DETECTING_WAKE_WORD to STOPPING
[20:03:37.529][D][voice_assistant:482]: State changed from STARTING_MICROPHONE to START_PIPELINE
[20:03:37.529][D][micro_wake_word:274]: Inference task is stopping, deallocating buffers
[20:03:37.529][D][micro_wake_word:279]: Inference task is finished, freeing task resources
[20:03:37.529][D][micro_wake_word:378]: State changed from STOPPING to STOPPED
[20:03:37.540][D][voice_assistant:229]: Requesting start
[20:03:37.540][D][voice_assistant:482]: State changed from START_PIPELINE to STARTING_PIPELINE
[20:03:37.598][D][voice_assistant:504]: Client started, streaming microphone
[20:03:37.606][D][voice_assistant:482]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[20:03:37.618][D][voice_assistant:489]: Desired state set to STREAMING_MICROPHONE
In any case, the assist entity never changes to listening. It stays idle.
Edit 2: Forget it. I noticed the test pipeline I was using was missing STT config. After fixing that, both your config and my basic one worked fine. ffs I feel stupid.
I’m reminded by myself, several times a day, that I know nothing :smiley:
All part of the process! Glad you got it working
I’ve been attempting to use the $13 Voice Assistant tutorial only to find that it doesn’t recognise the Atom Echo S3R. Do I understand correctly that the yaml above should be an appropriate setup for this device as a voice assistant in Home Assistant?
(newbie to the voice aspects for HA, and to ESPHome)
… ah, it looks like it more resembles the S3-BOX example. Anyway I’ve managed to get this working using a modified version of the yaml file shared above, thanks!
Hi @andypiper, would you mind sharing, what you altered to get it running?
