Initial Configuration Issue
First of all, thank you for this wonderful community and product. I am a complete noob so please be patient while I completely understand what I am doing wrong.
Now to the main point.
So I started off installing Home-Assistant (HA) on ras-pi. And configs are as below.
Ras-Pi (2) : Ubuntu 16.04
Nginx for proxy server
Let’s Encrypt for SSL certs
Domains: example.com -> port 80 and 443; home.example.com -> port 80 and 443 -> proxy to localhost:8123
And finally, HA running with docker.
The problem right now is that I can see the front end properly, but I can’t log-in with a default password ‘welcome’. I tried changing the password to my own password, but it still doesn’t let me in. I am not sure what I am doing wrong here, or I am missing some steps I have to make before I can log-in initially. If anyone is concerned about logs here it is.
2017-12-19 19:25:45 INFO (MainThread) [homeassistant.setup] Setting up updater
2017-12-19 19:25:45 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0
seconds.
2017-12-19 19:25:45 INFO (MainThread) [homeassistant.core] Bus:Handling <Event
component_loaded[L]: component=updater>
2017-12-19 19:25:47 INFO (MainThread) [homeassistant.setup] Setting up tts
2017-12-19 19:25:49 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over
10 seconds.
2017-12-19 19:25:50 INFO (MainThread) [homeassistant.setup] Setting up conversation
2017-12-19 19:25:50 INFO (MainThread) [homeassistant.core] Bus:Handling <Event
service_registered[L]: domain=conversation, service=process>
2017-12-19 19:25:50 INFO (MainThread) [homeassistant.setup] Setup of domain conversation took
0.0 seconds.
component_loaded[L]: component=conversation>
2017-12-19 19:25:53 INFO (MainThread) [homeassistant.setup] Setting up discovery
2017-12-19 19:25:53 INFO (MainThread) [homeassistant.setup] Setup of domain discovery took 0.1
seconds.
2017-12-19 19:25:53 INFO (MainThread) [homeassistant.core] Bus:Handling <Event
component_loaded[L]: component=discovery>
2017-12-19 19:25:55 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.yr
2017-12-19 19:25:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event
state_changed[L]: entity_id=sensor.yr_symbol, old_state=None, new_state=<state
sensor.yr_symbol=unknown; attribution=Weather forecast from yr.no, delivered by the Norwegian
Meteorological Institute and the NRK., friendly_name=yr Symbol,
entity_picture=//api.met.no/weatherapi/weathericon/1.1/?symbol=None;content_type=image/png @
2017-12-19T19:25:56.129905-05:00>>
2017-12-19 19:25:58 WARNING (MainThread) [homeassistant.setup] Setup of tts is taking over 10
seconds.
2017-12-19 19:25:58 INFO (MainThread) [homeassistant.core] Bus:Handling <Event
state_changed[L]: entity_id=sensor.yr_symbol, old_state=<state sensor.yr_symbol=unknown;
attribution=Weather forecast from yr.no, delivered by the Norwegian Meteorological Institute and
the NRK., friendly_name=yr Symbol, entity_picture=//api.met.no/weatherapi/weathericon/1.1/?
symbol=None;content_type=image/png @ 2017-12-19T19:25:56.129905-05:00>, new_state=<state
sensor.yr_symbol=3; attribution=Weather forecast from yr.no, delivered by the Norwegian
entity_picture=//api.met.no/weatherapi/weathericon/1.1/?symbol=3;content_type=image/png @
2017-12-19T19:25:58.340256-05:00>>
2017-12-19 19:25:58 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 19.1
seconds.
component_loaded[L]: component=sensor>
2017-12-19 19:25:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event
service_registered[L]: domain=tts, service=google_say>
service_registered[L]: domain=tts, service=clear_cache>
2017-12-19 19:25:59 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 11.8
seconds.
component_loaded[L]: component=tts>
2017-12-19 19:25:59 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in
37.19s
2017-12-19 19:25:59 INFO (MainThread) [homeassistant.core] Starting Home Assistant core loop
homeassistant_start[L]>
2017-12-19 19:25:59 INFO (MainThread) [homeassistant.core] Timer:starting
2017-12-19 19:26:02 INFO (MainThread) [homeassistant.components.http] Serving / to 172.17.0.1
(auth: False)
2017-12-19 19:26:07 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2017-12-19 19:26:08 INFO (MainThread) [homeassistant.components.http] Serving /manifest.json
to 172.17.0.1 (auth: False)
2017-12-19 19:26:15 INFO (MainThread) [homeassistant.components.http] Serving /api/websocket
2017-12-19 19:26:17 INFO (MainThread) [homeassistant.components.http] Serving /api/websocket
2017-12-19 19:26:19 INFO (MainThread) [homeassistant.components.http] Serving /api/websocket
2017-12-19 19:26:21 INFO (MainThread) [homeassistant.components.http] Serving /api/websocket
2017-12-19 19:26:24 INFO (MainThread) [homeassistant.components.http] Serving /api/websocket
Not sure if anything else will help or not, but if anything let me know and I will try to provide it.
Will really appreciate the help here.
NGINX is handling the SSL?
Is there anything in the NGINX logs showing your connections?
Wow! That was so dumb of me. Thanks for pointing me to RTFM and open debugger and see what I was doing wrong. It is now working as expected.
Thanks again for the fix.
