Innr SP242 not reporting correct values on latest firmware 1.7.23
Hi there, I had this issue before.
The firmware 1.7XX is not the latest.
Firmware 1.7XX reports the values ~100x (or 10x, doesn’t matter) higher than it should be
Firmware 1.9XX reports it correctly.
I have a mix of both firmware 1.7 and 1.9
I am using the normal zigbee integration
If all your plugs are like this, and you want a quick fix, consider following this guide:
Though when you update any to 1.9XX, you will have some reporting correctly, some incorrectly so I don’t recommend this.
Otherwise, updating to firmware 1.9XXX FIXES this issue.
For me, I had to go to:
YOUR_HOMEASSISTANT_URL/config/updates and check for updates, then update the device.
But I am using the normal zigbee integration, if you’re using zigbee2mqtt ( you don’t need to btw) try this:
My recommendation, is if you have a zigbee dongle, just pair the device with the normal zigbee integration and remove zigbee2mqtt ( home_assistant_url /integrations/zha/ )
The device will turn on and off when updating, so make sure you don’t have your home assistance machine being monitored with the plug :slight_smile:
