Innr wifi smart bulb integration
A integration for innr wifi smart bulb (without zigbee) would be nice
Do you mean matter?
I’m pretty sure all the Innr stuff uses matter to communicate.
https://www.amazon.de/gp/product/B08P3SWPW8/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
I don’t think they use matter. I tried and i can’t find them with matter.
Hmm, I could be wrong, but I thought all the new ones were.
Did they have a barcode on them in the box for pairing?
Yes they have barcode in the box. This barcodes works fine within in official innr IOS app. But with matter pairing via ios homeassist companion it doesn’t work.
I’m weak on how matter works and only know stuff I read. Read up on how matter pairs. It is possible that if you used the barcode to pair in the ios app, it is matter and it is matter paired to the apple world and cannot be paired using the barcode to anything else. It would have to be transferred elsewhere or just talked to thru the existing pairing.
Yeah, i tried scanning barcode, holding iphone near bulb and also factory reset. Doesn’t work. I also tried to add them to google home with matter. Also doesn’t work. I really think the only wifi bulbs from innr don’t use matter.
We probably need a integration for home assistant which connects to the innr app / api. Like we have with TP Smart Link / TAPO integration.
I am in the same situation, but different innr bulbs, mine are the Innr B22 RGB wifi bulbs (WBY-785), it only connects via WiFi, and it works with innr’s own app, Alexa and Google Home, but it does not work with any hub at all, like Hue bridge or zigbee dongles, the bulbs itself doesn’t have zigbee nor matter connectivity, so I’m not able to add it to Z2M
Here is a link to the product:
https://amzn.eu/d/fWr0VkW
