Inovelli Blue Series 2-in-1 Not Sending (some) ZHA Events
I have my Blue Series 2-in-1 switch mostly working, however, it will not send ZHA events without the settings configured to control something. For example, I want to use the config button to toggle the blue series fan canopy via NodeRed automation, but the only way Home Assistant see’s the config button was pressed is if I bind the button to the canopy. I do not want to do this because it will be double press for on (medium power) and hold for off, and that is not the behavior I want. Further, I cannot get scenes to work. Double tap works if I enable the switch in the settings, but triple click does not send a ZHA command.
Button Delay is set to 1, and On/Off Transition is set to 1. The paddles are bind(ed?)/bound to the fan canopy module. The Output Mode is On/Off.
