I recently switched to using Z-Wave JS to MQTT so that I could configure associations by using the GUI.
After switching to this my transitions defined in automations seem to no longer work. If I have something like this (below). It ignores the transition instead of stepping up slowly to brightness 80. It used to slowly step up the light to 80 before I switched to Z-Wave JS :
alias: Test
description: ''
- platform: sun
event: sunrise
offset: '00:00:00'
condition: []
- service: light.turn_on
transition: 10
brightness_pct: 80
entity_id: light.downstairs_living_room
mode: single
I thought as a workaround I could just adjust the dimmer setting on the inovelli switches before, adjusting the brightness of the light. But If I do something like this:
I just get the error: zwave_js_server.exceptions.InvalidNewValue: Must provide a value that represents a valid state key or label from {“0”: “Immediate”}
