I have a Inovelli VZM31-SN that I have automations that set LED notifications. I see there is a parameter on the switch to set a default on and off value for the LEDs. But I can’t figure out how to activate the defaults?
For example, I have a LED notification that pulses the LED green if my shed door is left open. When the door closes, I want the LEDs to go back to the default on or off depending on the state of the light the switch controls.
The best I can figure out is that I have to just know what the default values are and manually set those values in my automation. This is working, but if I ever decided to change those default values, I would have to then update all my automations to match. Is there a way to have an automation simply tell the switch, “go back to your default”?
