Hi there!
I have an external process that tracks my wife and I’s phone and determines when we’re in our out of the house. I have defined two input_boolean’s for us in Home Assistant and then set them to on or off by making calls to the HASS API. I can tell this is working because I can see them change in the logbook.
However, it displays really oddly in the Overview tab. There’s an input_boolean section with the two variables I’ve defined, but instead of showing the toggle as Off when someone is out of the home, it shows as On regardless of whether the status is on of off.
Hope this makes sense!!
-Dan
If you definitely see the input boolean state in the dev tools states menu (lower left hand menu button looks like <>) ‘off’ and the front end is showing it as on then this should be reported as an issue.
