Input Boolean with IFTTT
Hi, I’m a newbie, I’m creating a smoking room with light and smoke-fan and this is what I want to make:
I’d like to have a control panel with on/off switches that send IFTTT command. I need a switch that when is on can send “turn it on” to my IFTTT devices and send “shut down” when is turned off.
I’ve created my IFTTT applet and are working from my phone with Google Assistant, so I’m sure that the command reaches my devices.
I started to write down yaml configuration, but I got a lot of trouble.
Please can anyone check my code and help me?
configuration.yaml
# Zona Fumatori
ifttt:
 key: secret_code
luci_fumatori_accese:
 sequence:
  - service: ifttt.trigger
    data_template: {"event": "luci_fumatori_on"}
luci_fumatori_spente:
 sequence:
    data_template: {"event": "luci_fumatori_off"}
aspiratore_fumatori_acceso:
 sequence:
    data_template: {"event": "aspiratore_fumatori_on"}
aspiratore_fumatori_spento:
 sequence:
    data_template: {"event": "aspiratore_fumatori_off"}
# luci Fumatori
input_boolean:
 luci_fumatori:
    initial: off
    icon: mdi:lightbulb-outline
 aspiratore_fumatori:
    initial: off
    icon: mdi:fan
# Cloud
cloud:
group: !include groups.yaml
groups.yaml
group:
  view: yes
  entities:
   - group.ZonaFumatori
ZonaFumatori:
 entities:
  - switch.luci_fumatori_accese
  - switch.luci_fumatori_spente
  - switch.aspiratore_fumatori_acceso
  - switch.aspiratore_fumatori_spento
automation.yaml
automation:
 - alias: 'Luci Zona Fumatori'
    platform: homeassistant
    event: start
   condition:
     entity_id: input_boolean.luci_fumatori
     state: true
     data: {"event": "luci_fumatori_on"}
 - alias: 'Aspiratore Zona Fumatori'
    event: start
   condition:
     entity_id: input_boolean.aspiratore_fumatori
     state: true
     data: {"event": "aspiratore_fumatori_on"}
IMO you are going about this the wrong way. If you want a toggle that sends on/off to 2 different sequences, use a switch template. No automations required. You’ll need to figure out something for the status of the switch but you can at least program the on/off explicitly.
ok, thank you, I’ll try and make you know!!!
I used this page like this:
switch:
    switches:
      luci_fumatori:
        friendly_name: "Luci Fumatori"
        icon_template: mdi:lightbulb-outline
        value_template: "{{ is_state('input_boolean.luci_aspiratore', 'on') }}"
        turn_on:
            entity_id: switch.luci_fumatori_acceso
        turn_off:
            entity_id: switch.luci_fumatori_spento
but:
General Errors:
- Error loading /Users/dan/.homeassistant/configuration.yaml: while parsing a block mapping
in “/Users/dan/.homeassistant/configuration.yaml”, line 78, column 11
expected , but found ‘’
in “/Users/dan/.homeassistant/configuration.yaml”, line 80, column 13
You don’t need your scripts, if you are using the input boolean as your on/off indicator, then you need to turn that on/off as well.
  turn_off:
    - service: home_assistant.turn_off
      entity_id: input_boolean.luci_aspiratore
        event: "luci_fumatori_off"
I suggest you brush up on the yaml, converting json dictionaries to yaml, and the home assistant database. You should look into what domains are.
Thanks so much!
I did like this:
configuration.yaml
switch:
    switches:
      zona_fumatori:
        friendly_name: "Zona Fumatori (luci+aspiratore)"
        icon_template: mdi:smoking
        value_template: "{{ is_state('switch.zona_fumatori', 'on') }}"
        turn_on:
        turn_off:
           entity_id: switch.zona_fumatori
            event: "aspiratore_fumatori_off"
      luci_fumatori:
        value_template: "{{ is_state('switch.luci_fumatori', 'on') }}"
        turn_on:
          - service: home_assistant.turn_on
             event: "luci_fumatori_on"
        turn_off:
        friendly_name: "Aspiratore Fumatori"
        icon_template: mdi:fan
        value_template: "{{ is_state('switch.aspiratore_fumatori', 'on') }}"
        turn_on:
        turn_off:
            entity_id: switch.aspiratore_fumatori
customize.yaml
switch.luci_fumatori:
  assumed_state: true
switch.aspiratore_fumatori:
  assumed_state: true
switch.zona_fumatori:
  assumed_state: true
I don’t think that will work, you are referencing itself inside itself.
You’ll need those input_booleans instead.
ok, I changed…but was working also with autoreference (???)!!!
If it works, then use it. but you may run into errors when the object is referencing itself. I could see it become a memory leak because calling turn_on will call tun_on which will call turn_on which will call turn_on… forever.
I changed back to input_boolean
like this:
switches:
      zona_fumatori:
        value_template: "{{ is_state('input_boolean.zona_fumatori', 'on') }}"
        icon_template:
          "{% if is_state('input_boolean.zona_fumatori', 'on') %}
            mdi:smoking
          {% else %}
            mdi:smoking-off
          {% endif %}"
        turn_on:
        turn_off:
           entity_id: input_boolean.zona_fumatori
      luci_fumatori:
        value_template: "{{ is_state('input_boolean.luci_fumatori', 'on') }}"
        icon_template:
          "{% if is_state('input_boolean.luci_fumatori', 'on') %}
            mdi:lightbulb-on-outline
          {% else %}
          {% endif %}"
        turn_on:
        turn_off:
        value_template: "{{ is_state('input_boolean.aspiratore_fumatori', 'on') }}"
        icon_template:
          "{% if is_state('input_boolean.aspiratore_fumatori', 'on') %}
            mdi:fan
          {% else %}
            mdi:fan-off
          {% endif %}"
        turn_on:
             event: "aspiratore_fumatori_on"
        turn_off:
and it works fine!!! (a little bit of lag, but ok!)
but can’t change icon according to status…or have a sort of light on/off
There will be lag on the interface, you’ll train yourself to ignore that. If you are getting lag to your devices, reorder the services in turn_on/turn_off. Place your highest priority items first, and placing input_boolean last because that’s just visual.
I changed putting the “icon code” at the and to be solved after the switch selection…but doesn’t work…
        turn_on:
        turn_off:
        icon_template:
            mdi:fan
          {% else %}
            mdi:fan-off
          {% endif %}"
No no no, When i was saying reorganize the services, i mean just the services. Not the other attributes.
These are the services under turn_on:
event: “aspiratore_fumatori_on”
These are the servcies under turn_off:
Re order those, example:
Also, you need another space before the word event in all your ifttt.trigger services.
Hello DanPal
I’m also a newbie
I’m trying to realise a similar Solution like you. Can you provide me your code, please?
Greetings from switzerland
Tom
His code is posted multiple times in this thread. Just take a look at his last few comments. Both have working versions of his code
Hello Petro
I have no idea which parts of the code I need. Isn’t it possible that you can send me a copy of the code I need?
Greetings
Tom
Every automation is unique, copying and pasting code won’t work. You’ll have to doctor it, this link has the info you want:
Petro
Many thanks to you. I’ll try it.
Greetins
Tom
