!input in automation/blueprint + templates
I’ve modified a blueprint to my need but I want to make it more generic.
One of the things I changed was the control of brightness:
              brightness_step_pct: >
                {% if (state_attr('light.lampada_lara', 'brightness')/2.54) > 20 %}
                  -20
                {% elif 11 < (state_attr('light.lampada_lara', 'brightness')/2.54) < 20 %}
                  -10
                {% elif (state_attr('light.lampada_lara', 'brightness')/2.54) <= 11 %}
                  {{ 1-(state_attr('light.lampada_lara', 'brightness')/2.54) }}
                {% endif %}
As you can see I’ve put the entity name there.
The original blueprint always call the entity as
              entity_id: !input zha_entity_light
So I tried many things to replace ‘light.lampada_lara’ to !input zha_entity_light withou sucess.
I tried the following:
‘!input zha_entity_light’
“!input zha_entity_light”
I also tried to add a variable:
variables:
  device_id: !input zha_device
  light_id: !input zha_entity_light
and then use the variable there as:
light_id
‘light_id’
[light_id]
But those didn’t work.
Is there a solution?
Tks
You cannot use the yaml !input method directly in templates, you must assign the value of the input to a variable as in you did in
variables:
Depending on how/where in the automation you need access to that data, you may need to assign them as trigger_variables. Then your template would be as follows:
  {% set brightness = state_attr(light_id, 'brightness') / 2.54 %}
  {% if brightness > 20 %}
    -20
  {% elif 11 < brightness < 20 %}
    -10
  {% elif brightness <= 11 %}
    {{ 1 - brightness }}
  {% endif %}
Tried that and got
“Error: Error rendering data template: AttributeError: ‘list’ object has no attribute ‘lower’”
Here is the “Automation config” in Traces
That error is not coming from that part of the blueprint
So where does it come from?
Here is the print from trace
And here is the full code from blueprint:
blueprint:
  domain: automation
  name: Controlling lights using Philips Hue Dimmer Switch (RWL021)
  description: Take the swith fast into use with pre-set configuration.
  input:
    zha_device:
      name: Philips Hue Dimmer Switch (RWL021 only)
      description: The swith to be taken into use.
      selector:
        device:
          integration: zha
          model: RWL021
          multiple: false
    zha_entity_light:
      name: Light or a light group
      description: Light or a light group to be controlled.
      selector:
        entity:
          multiple: true
          integration: zha
          domain:
            - light
  source_url: https://gist.github.com/Rantaki/33c9e74821e08c4419539e7a8e46007c
mode: queued
max_exceeded: silent
variables:
  - platform: event
    event_type: zha_event
condition: "{{ trigger.event.data.device_id == device_id }}"
  - variables:
      command_type: "{{ trigger.event.data.command }}"
  - service: logbook.log
      message: "{{ device_id }}"
      message: "{{ command_type }}"
      message: "{{ trigger.event.data.device_id }}"
  - choose:
      - conditions: '{{ command_type == "on_press" }}'
        sequence:
          - service: light.turn_on
              brightness_pct: 100
              transition: 0.3
      - conditions: '{{ command_type == "off_press" }}'
        sequence:
          - service: light.turn_off
              transition: 0.3
      - conditions: '{{ command_type == "down_hold" }}'
        sequence:
                  -20
                  -10
                {% endif %}
              transition: 0.4
      - conditions: '{{ command_type == "up_hold" }}'
        sequence:
              brightness_step_pct: 15
              transition: 0.4
      - conditions: '{{ command_type == "up_short_release" }}'
        sequence:
              brightness_pct: 70
              transition: 0.3
      - conditions: '{{ command_type == "down_short_release" }}'
        sequence:
              brightness_pct: 10
              transition: 0.3
  - choose:
      - conditions:
          '{{ command_type == "on_press" or command_type == "up_short_release"
        sequence:
          - delay: 0.4
              kelvin: 3400
              transition: 0.5
        sequence:
          - delay: 0.4
              kelvin: 2300
              transition: 0.5
Does anyone have any clues? Tks
