Why is my input_select changing twice when I run a scene? It changes to Home then to what it is suppose to change to. Here is one of my scenes. Do I need to delete all the options except the one I’m changing to?
- id: '1633835740895'
name: Up Early HA
entities:
input_select.house_state:
options:
- Home
- Away
- Gone
- Hoss Home Alone
- Kids Bed Time
- Night
- On Way Home
- Visitor
- Visitor Night
- Up Early
editable: true
friendly_name: House State
state: Up Early
switch.kitchen_light:
friendly_name: Kitchen Light
icon: hass:lightbulb
state: 'on'
I’ll start by saying that i’m not very familiar with scenes
If you are setting the state of the input_select, why do you need the options listed in the scene ?
That was the code that was made from making the scene. I went to configuration on the left, selected scenes, then hit + add scene. When I went into file editor this is the code I found that was made.
With Siri. Here is the logs. Every scene I have I noticed goes to Home first before going to what it should be.
[Kitchen Light](http://homeassistant.local:8123/logbook#) turned on by [Up Early HA](http://homeassistant.local:8123/logbook#)
8:05:19 AM - 2 hours ago
[House State](http://homeassistant.local:8123/logbook#) changed to Up Early by [Up Early HA](http://homeassistant.local:8123/logbook#)
8:05:17 AM - 2 hours ago
[Alarmo](http://homeassistant.local:8123/logbook#) changed to Disarmed by [Set Alarm To Disarm](http://homeassistant.local:8123/logbook#)
[Set Alarm To Disarm](http://homeassistant.local:8123/logbook#) has been triggered by state of input_select.house_state by [Up Early HA](http://homeassistant.local:8123/logbook#)
8:05:16 AM - 2 hours ago
[House State](http://homeassistant.local:8123/logbook#) changed to Home by [Up Early HA](http://homeassistant.local:8123/logbook#)
[HomeKit](http://homeassistant.local:8123/logbook#) send command turn_on for Up Early HA
8:05:16 AM -
Guess I found a work around. After making the scene go into file editor then automations. I deleted all the options: and the editable: I had to restart for it to work reliably. Before the restart sometimes it would work properly sometimes it would change to Home then to the proper state:
