Input select for time not working in automation
I want to use an input select for time and then trigger an action when this occurs, but nothing happens. Can someone see what is wrong?
input_select:
  select_light_time:
    name: Light ON at
    options:
      - "21:35"
      - "09:40"
      - "08:45"
      - "08:50"
      - "08:55"
    initial: "21:35"
  - alias: Light ON 6.30
      platform: template
      value_template: '{{ states.input_select.select_light_time.state }}'
    condition:
      condition: and
      conditions:
        - condition: sun
          before: sunrise
        - condition: time
          weekday:
            - mon
            - tue
            - wed
            - thu
            - fri
      - service: switch.turn_on
        entity_id: switch.sonoff_1_light
I think you are triggering on the state of the input_select changing not the time being at whatever you’ve set in the input_select
okay that sounds plausible but do you know what must be changed to make it work then?
This what I do for my alarm…
 - alias: 'Wake Me Up'
   initial_state: 'on'
     - platform: time
       minutes: '/1'
       seconds: '0'
   condition:
      condition: or
      conditions:
        - condition: and
          conditions:
            - condition: state
              entity_id: input_boolean.alarmstatus
              state: 'on'
            - condition: state
              entity_id: input_boolean.alarmweekday
              state: 'on'
            - condition: time
              weekday:
                - mon
                - tue
                - wed
                - thu
                - fri
                - sat
            - condition: template
              value_template: '{{ now().time().strftime("%R") == states.sensor.alarm_time.state }}'
        - condition: and
          conditions:
            - condition: state
              state: 'on'
            - condition: state
              state: 'off'
I trigger every minute then check against now().time().strftime("%R") == states.sensor.alarm_time.state
