Hi All,
Just seeking clarification that the initial value in a input_select cannot use jinja2 templating for a response.
I have a input_select:
ground_hvac_climate_mode:
name: Ground HVAC Climate Mode
options:
- 'Off'
- Heat
- Cool
initial: Heat
icon: mdi:sun-snowflake-variant
When I use the input select as:
options:
- 'Off'
- Heat
- Cool
initial: |
{% for now().month in [4,5,6,7,8,9,10] %}
Heat
{% else %}
"Off"
{% endif %}
then the system generates an error
Logger: homeassistant.config
Source: config.py:942
First occurred: 10:57:27 (1 occurrences)
Last logged: 10:57:27
Invalid config for ‘input_select’ at input_selects/hvac.yaml, line 9: initial state {% if now().month in [4,5,6,7,8,9,10] %} Heat {% else %} “Off” {% endif %} is not part of the options: Off,Heat,Cool for dictionary value ‘input_select->ground_hvac_climate_mode’, got {‘name’: ‘Ground HVAC Climate Mode’, ‘options’: [‘Off’, ‘Heat’, ‘Cool’], ‘initial’: ‘{% if now().month in [4,5,6,7,8,9,10] %}\n Heat\n{% else %}\n “Off”\n{% endif %}\n’, ‘icon’: ‘mdi:sun-snowflake-variant’}, please check the docs at Input select - Home Assistant
So no jinja templating for initial value is allowed? Am I doing something wrong?
