Input_select not working after update to 21.1
I’m running two raspberry pis with HAss. Trying different things on different devices. Both were installed with the all in one installer. Yesterday I updated on of them to 21.1 since then all input_selects do not work. tailing the log files no longer shows any changes when changing the input select. Sliders still work, setting the value in the dev tools works. All automations based on the inputs have also stopped working (unless you set their value with dev tools). Anyone else having this issue?
I have the same issue. Did you solved it ?
Yeah the update to 0.21.2 solved the issue.
I didn’t see this update, thank a lot :slight_smile:
Glad it helps man! I should have updated the post. My bad.
