Inquiry: Tuya Knob dimmer switch with 1.2 inch Display
I purchased this device with the hope of being able to automate some of LED downlights which are wired to a MOES Dimmer Switch. However, It looks that the device can only be used with Zigbee lights and (maybe) Zigbee dimmer drivers. I wanted a solution (device) can easily be used to control the dimming for those lights wired to Zigbee Dimmer Switches (I have MOES dimmer switches). I tried the Groups function but it doesn’t seem to work, basically when I use the Smart Life app, the Knob dimmer device doesn’t show any groups of MOES dimmer switches that were created!
The knob dimmer switch has 5 main parts:
A) Turn on/off the knob display screen.
B) Change the knob function: Brightness or Temperature
C) Has two options: when wired L1 will turn on/off the respective device its wired to. When not wired, it used to trigger a scene or a remote device.
D) Has two options: when wired L2 will turn on/off the respective device its wired to. When not wired, it used to trigger a scene or a remote device.
E) When rotated, increases the brightness or temperature, first click on (B) to change the mode for either brightness or temperature
Does anyone have experience with such device or have come across such topics? I have videos of the device and how it functions below.
https://drive.google.com/drive/folders/13CuDLSJ_AZHSaifdu1lZDU0Ehqe38heJ?usp=sharing
