Hi, I recently bought a Zigbee Pushbutton Interface from Insta GmbH.
Adding it to the ZHA ZigBee network worked flawlessly.
The problem is that there are no events I can hook up with automations (other than the identify button ones). However, some events appear to be logged in the loogbook.
I’m not sure what the problem is. Do I have to configure something with the NEXENTRO Config app?
Diagnostic information
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2023.1.0",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.7",
"docker": true,
"arch": "armv7l",
"timezone": "Europe/Berlin",
"os_name": "Linux",
"os_version": "5.15.76-v7",
"supervisor": "2022.12.1",
"host_os": "Home Assistant OS 9.4",
"docker_version": "20.10.19",
"chassis": "embedded",
"run_as_root": true
"custom_components": {},
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/zha",
"requirements": [
"bellows==0.34.5",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.90",
"zigpy-deconz==0.19.2",
"zigpy==0.52.3",
"zigpy-xbee==0.16.2",
"zigpy-zigate==0.10.3",
"zigpy-znp==0.9.2"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"codeowners": [
"@dmulcahey",
"@adminiuga",
"@puddly"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"type": "_zigstar_gw._tcp.local.",
"name": "*zigstar*"
"type": "_slzb-06._tcp.local.",
"name": "slzb-06*"
"dependencies": [
"file_upload"
"after_dependencies": [
"onboarding",
"usb",
"zeroconf"
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"is_built_in": true
"data": {
"ieee": "**REDACTED**",
"nwk": 32105,
"manufacturer": "Insta GmbH",
"model": "NEXENTRO Pushbutton Interface",
"name": "Insta GmbH NEXENTRO Pushbutton Interface",
"quirk_applied": false,
"quirk_class": "zigpy.device.Device",
"manufacturer_code": 4474,
"power_source": "Mains",
"lqi": 248,
"rssi": -84,
"last_seen": "2023-01-05T20:42:58",
"available": true,
"device_type": "Router",
"signature": {
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4474, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
"endpoints": {
"4": {
"profile_id": 260,
"device_type": "0x0105",
"in_clusters": [
"0x0000",
"0x0003"
"out_clusters": [
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x0008",
"0x0019",
"0x0300"
"5": {
"profile_id": 260,
"in_clusters": [
"0x0000",
"0x0003"
"out_clusters": [
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x0008",
"0x0019",
"0x0300"
"7": {
"profile_id": 260,
"device_type": "0x0203",
"in_clusters": [
"0x0000",
"0x0003"
"out_clusters": [
"0x0003",
"0x0004",
"0x0019",
"0x0102"
"242": {
"profile_id": 41440,
"device_type": "0x0061",
"in_clusters": [],
"out_clusters": [
"0x0021"
"active_coordinator": false,
"entities": [
"entity_id": "button.insta_gmbh_nexentro_pushbutton_interface_identify",
"neighbors": [],
"routes": [],
"endpoint_names": [
"name": "COLOR_DIMMER_SWITCH"
"name": "WINDOW_COVERING_CONTROLLER"
"name": "unknown 97 device_type of 0xa1e0 profile id"
"user_given_name": null,
"device_reg_id": "8dab62ebda6d89aff874774ea3d9f8e9",
"area_id": "simon",
"cluster_details": {
"4": {
"device_type": {
"name": "COLOR_DIMMER_SWITCH",
"id": 261
"profile_id": 260,
"in_clusters": {
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {
"0x0004": {
"attribute_name": "manufacturer",
"value": "Insta GmbH"
"0x0005": {
"attribute_name": "model",
"value": "NEXENTRO Pushbutton Interface"
"unsupported_attributes": {}
"0x0003": {
"endpoint_attribute": "identify",
"attributes": {},
"out_clusters": {
"0x0003": {
"attributes": {},
"0x0004": {
"endpoint_attribute": "groups",
"attributes": {},
"0x0005": {
"endpoint_attribute": "scenes",
"attributes": {},
"0x0006": {
"endpoint_attribute": "on_off",
"attributes": {},
"0x0008": {
"endpoint_attribute": "level",
"attributes": {},
"0x0019": {
"endpoint_attribute": "ota",
"attributes": {},
"0x0300": {
"endpoint_attribute": "light_color",
"attributes": {},
"5": {
"device_type": {
"id": 261
"profile_id": 260,
"in_clusters": {
"0x0000": {
"attributes": {},
"0x0003": {
"attributes": {},
"out_clusters": {
"0x0003": {
"attributes": {},
"0x0004": {
"attributes": {},
"0x0005": {
"attributes": {},
"0x0006": {
"attributes": {},
"0x0008": {
"attributes": {},
"0x0019": {
"attributes": {},
"0x0300": {
"attributes": {},
"7": {
"device_type": {
"name": "WINDOW_COVERING_CONTROLLER",
"id": 515
"profile_id": 260,
"in_clusters": {
"0x0000": {
"attributes": {},
"0x0003": {
"attributes": {},
"out_clusters": {
"0x0003": {
"attributes": {},
"0x0004": {
"attributes": {},
"0x0019": {
"attributes": {},
"0x0102": {
"endpoint_attribute": "window_covering",
"attributes": {},
"242": {
"device_type": {
"name": "unknown",
"id": 97
"in_clusters": {},
"out_clusters": {
"0x0021": {
"endpoint_attribute": "green_power",
"attributes": {},
