Install and upgrade confusion
I appear to have managed, during an upgrade I think, end up with two versions of Home Assistant (only 1 running) on my Pi 4B.
I also use my Pi as a print server / VPN server / single channel 5Ghz access point for Firestick and plan to tap into my home motion and door sensors via GPIO ports hence I was keen on a core install.
I have ended with a /var/opt/homeassistant that I’ve put a lot of time into configuring but struggling to upgrade from it’s running 0.115.6
/etc/init.d Service Script for Home Assistant
Created with: Sample /etc/init.d script · GitHub
PRE_EXEC=“”
Typically /usr/bin/hass
HASS_BIN=“/srv/homeassistant/bin/hass”
RUN_AS=“homeassistant”
PID_DIR=“/var/run/hass”
PID_FILE=“$PID_DIR/hass.pid”
CONFIG_DIR=“/var/opt/homeassistant”
LOG_DIR=“/var/log/homeassistant”
LOG_FILE=“$LOG_DIR/home-assistant.log”
FLAGS=“-v --config $CONFIG_DIR --pid-file $PID_FILE --log-file $LOG_FILE --daemon”
Annnnnd I appear to have $HOME/.homeassistant that does appear current and I think is a result of using ‘pip install’ (I have no idea about pip / python - dangerous I know) and runs a virgin instance if I stop my running hass and fire up hass from the command line.
What is the best way to run Home Assistant on a Pi that I need to solve other home network problems? I don’t want to try and fix the above if there is a better way.
Many thanks in advance.
IMHO Home Assistant Container with docker-compose or Portainer on Rasperry Pi OS.
Thanks for the reply
Exposing USB and GPIO from Pi OS to the docker environment is OK
Is that a statement or a question?
haha missed the ?
Yes a question
Sure about USB (use --device parameter for Docker cli), confident about GPIO, either directly or remote.
cheers - just need to read up about Docker as I assume its like a VM
